Results 1 to 12 of 12
    2,088
    Gravedigger 4wd brushless gearing ?
    Just wondering what would you all recomend for the gearing? in me e revo it has 28/50 and i know the summit is 16/50,,,,the stock digger big block brushed gearing is 23/55. thanks for the help.
    Alma, MI
    12,287
    It would probably need to be along the lines of the Summit gearing.
    Colorado Springs, CO.
    2,013
    16/50 is brushless summit stock....
    you can also do 11-17/55
    anything else isnt recommended on the VXL with the large tires
    383
    17 pinion probably easiest as you won't have to change the spur.
    2,088
    so i dont have much for gears i had to order some but for now it has 18/50.... i wonder should i put the 55 t back in for now?
    Alma, MI
    12,287
    That sounds like a plan!
    2,088
    so then i should put the 55t back in?
    2,013
    if you put the 55 back in, you will have more gears to choose from...with the 50, only the 16 is recommended and I dont think the smaller gears will reach with the 50 on it....I could be wrong as I dont have those gears to try right now
    cincinnati oh
    110
    Quote Originally Posted by jaman View Post
    W
    What battry with the 18 50 setup?
    2,088
    2- 1600 mah nimh batteries.
    cincinnati oh
    110
    18 50 was too much for the stock 1200 i think the truck fell on its face also. Im at 17 50 but going to get the 55 spur and some pinions for the snow bashing
    2,088
    ok, i put the 55t spur back in with an 18t pinion, seems to act normal on the hardwood floor.
