Results 1 to 14 of 14
Thread: Wheelies?
    Baton Rouge, La
    34
    Wheelies?
    Should I be able to make the truck wheelie on a 2s lipo pack? I am just trying to button things up before I give it to my son.
    May 2005
    Minnesota
    747
    Yes you can. You would have to tighten the clutch. I like to have my clutch a little lose.
    Sent from my ADR6300 using Tapatalk 2
    Bad Mutt VXL
    Stampede 4x4 Roller to be for sale!
    Dirty Jerz
    232
    also make sure your truck is not in training mode.
    I play til something breaks
    24
    It'll wheelie on nimh batteries. Remove the spur and slipper unit, tighten the slipper nut holding the spur with your fingers (ala 'finger tight') then back it off 1/8 to 1/4". Wheelie away
    Wales in the UK
    1,894
    The pede loves wheelies its all down to the slipper dude hope you have lots of fun with it as a family...peace
    Davenport, Iowa Quad Cities
    2,417
    We run the castle 3800's and can wheelie for days!
    Saginaw,MI
    212
    i have stock nimhs with slipper 1/4 tite and cant pull wheels off the ground!!!!!!!!
    RACE IT, BREAK IT, FIX IT, REPEAT!
    24
    Quote Originally Posted by atclauss View Post
    Training mode is off? Plenty of traction (no wheel spin)? If yes to both, try tightening the slipper more. Other than bad battery, esc or motor causing poor performance, if everything is stock then your slipper may be either too loose or possibly too worn. I suppose the latter likely if it's been run loose for a long time; a telltale sign is lots of clutch fibre built up around the rear diff housing where it meets the center shaft.
    3
    2wd or 4x4?
    Baton Rouge, La
    34
    I have the vxl 4x4 no wheelies yet. Still a work in progress.
    Okanagan Valley B.C.
    674
    Here is a quick vid of my pede on 2s, slipper is set at 1/8th out from full tight.
    Aug 2010
    new hampshire
    1,508
    Nice video.The mountains in the back ground look awesome.
    Good bear hunting in BC?
    Salisbury, NC
    633
    Quote Originally Posted by fishquiz View Post
    You've probably got a bind somewhere or an ESC/motor issue. Anyway, once you get things sorted out, you can put the bigger Revo Clutch in. You need to buy the pressure plate and rebuild kit and you can use your stock shaft and other parts. I wouldn't go beyond 1/4 turn on the slipper though or you will be breaking things like MIP coupler pins, axle pins, motor shafts, etc. of you run 3S Lipo.
    "The Voice of Expensive Experience".
    Dayton, Ohio USA
    59
    I was unable to pull wheelies in training mode, but when I went to sport mode, and had traction, I was wheeling like no other. I was using the stock 2S Lipo. Hope you get it figured out.
