Results 1 to 16 of 16
    Feb 2003
    Portsmouth, Ohio.
    76
    CVD Output Drive Cup
    My Summit is now running a full MErv suspension. I also have Traxxas CVD's and a rear differential lock. Ran fine with stock power cells. Went to LiPo. Different animal all together. So, with that being said. Today I broke an output drive cup. Can I purchase these individually? or, do I have to purchase a new set of CVD's just for the cups? Needless to say, the locker is coming out.
    Current labor of love.
    Traxxas Summit 1/16 VXL
    9,244
    Traxxas 7052
    Locking the diff is rarely a good idea
    Have you shimmed your diffs?
    Feb 2003
    Portsmouth, Ohio.
    76
    No. I've had the truck for 2 years. Never had any ring and pinion issues.
    9,244
    That's because you have been running nimh!
    Feb 2003
    Portsmouth, Ohio.
    76
    I'll check the mesh when I replace the drive cup. It will be going back to an open diff as well.
    9,244
    Only real way to check it is by shimming. Unless its real loose
    Feb 2003
    Portsmouth, Ohio.
    76
    It's been apart quite a few times. Never felt loose.
    Alma, MI
    12,280
    I have seen a tight feeling diff take 3 shims. It is hard to see or feel the slop when there is nothing pushing on the bulkheads to flex them. This flex is not really seen unless there is power fed to the gear set or when you stick a shim or three in there and realize the carrier still spins quite freely.
    Feb 2003
    Portsmouth, Ohio.
    76
    My lhs had the cups in stock. No gears or shims. I will have to order those. Hopefully my driveline won't need much more.
    Feb 2003
    Portsmouth, Ohio.
    76
    Just placed my order for shims and the internal gear set. I guess it's back to a teflon tape filled rear end or silly putty. Not a true locker how I like. It will give enough not to wind up breaking axles and cups.
    9,244
    Have you tried 100k diff oil? Twice as thick as most use
    Feb 2003
    Portsmouth, Ohio.
    76
    I've had several oils in the diff. Even auto 80W90. I've found the teflon tape or silly putty works the best for me. I couldn't wait this evening and changed the cup out. I've gotten pretty good at diff service. I have the cup changed, wheels on in 30 minutes.
    Alma, MI
    12,280
    80w90 is thinner than 100wt.
    Feb 2003
    Portsmouth, Ohio.
    76
    This time out I tamed down my driving style a bit. Still a wheelie monster. This thing would probably be useless or just a complete handful off road on 3S. The 55T spur isn't helping the matter.
    Feb 2003
    Portsmouth, Ohio.
    76
    I went out today. Went against best wishes and had a rear axle fly out. Lucky I found the axle, but without the drive and cross pins. Are those sold individually?
    9,244
    Traxxas 7055
