Results 1 to 7 of 7
    Lake Charles, LA
    66
    flywheel install
    When I tightened my flywheel now my motor is extremely tough to spin over by hand. Is this normal or am I missing something?
    Mar 2009
    1,752
    is the flywheel rubbing on the block or carb? if not your rear bearing is toast
    Lake Charles, LA
    66
    Seems to be rubbing on the front of the block. Just got my .21tm today and was moving the flywheel over to new motor. Got flywheel nut tight but then lots of resistance. Had trouble with crankshaft wanting to turn with the nut when I held flywheel with channelocks. When turning flywheel by hand nut finally just loosened itself.
    Mar 2009
    1,752
    ok.. well make sure the flywheel collet is in good shape and its the one made for the flywheel.. if all that is ok.. you need a washer behind the collet.. its going to need to be 7mm inside diameter...
    1,994
    You may have a bad collet, but more likely a bad flywheel.
    Lake Charles, LA
    66
    Thanks kgombe1. New to this and definitely still learning. Never put the collet on it was still stuck in the old crank!!! Oops. Thanks for all yalls help.
    Mar 2009
    1,752
    no problem man.. your welcome
