Page 1 of 2 1 2 LastLast
Results 1 to 40 of 42
Thread: Leopard merv
    Louisiana
    572
    Leopard merv
    No, not a leopard colored body. A leopard motor. I had the big block 5700 but it was too top heavy and just heavy all together. After looking around I decided on a leopard 2845 4420kv. It has a 4mm shaft so I drilled out my pinions with a 4mm drill bit. Had to grind the motor shaft a hair because it was too long. But other than that, it fits! Made a few passes on the street and the power and speed is comparable with the 5700. Temps were good too. Under 100°. will get better test results tomorrow and a GPS verified MPH. So far I'm very pleased!
    Rotterdam, Netherlands
    6,233
    Nice to know. I bought exactly the same for use in a boat. If it doesn't work there, I can still put it in one of my cars.
    Very affordable motor.
    9,245
    How did the drill job work?
    Just a little bit off would mean trouble
    Louisiana
    572
    Its not extremely perfect but it's not bad at all. Can't tell when checking gear mesh. Feels the same all around the gear. I used flat pliers and a drill press
    6,233
    I still have to build it into the boat, but my plan is to sand the motor shaft down to 3mm...
    Louisiana
    572
    That was option 2 if drilling the pinions didn't work out.
    9,245
    You could actually turn the motor over under power as you sand it
    6,233
    That was my plan. Lol.
    Louisiana
    572
    OK test results are in. I recommend this motor! Ran it on 2s. It launches like a rocket. Winds out too fast. I need a smaller spur gear. The pinion is around 26t. Top speed was 34mph and Max temp was about 115° will order more gearing options and update later
    Louisiana
    572
    I think instead of gearing up I will just do like everyone else and get bigger tires like the dirthawgs
    9,245
    I would do both!
    Louisiana
    572
    Yes!! If temps allow me to
    Lake Jackson, TX
    753
    I've been contemplating that chassis. Do you run the stock merv body with it? Good looking truck you have there
    Sl2sh Sl4shx2 Bandit Grave Digger MERV EMBEx2 P4de
    Louisiana
    572
    Thanks yes I run the stock body but you need to dremel the sides off with a cutoff wheel, otherwise the body will stick out. Its a wide chassis.
    Before cutting:
    After:
    Louisiana
    572
    Here is a short video from bashing today. Hope it works. Sorry that its blurry.
    https://www.youtube.com/watch?v=7sDA...e_gdata_player
    9,245
    your video comes up private
    time to upgrade your rims and tires to match your car!
    Louisiana
    572
    Not sure how to make it public. Will try to figure it out. Already have dirthawgs and these wheels on the way
    http://www.amainhobbies.com/product_...-2-1-16-E-Revo
    OK video works now!
    9,245
    zips around pretty good!
    Going to flip my car back over.
    717
    so would you recommend this motor over the stock one
    Louisiana
    572
    Not sure. I never ran the stock one. But it is 4 pole and it has 420 more kv so I would say it should have better performance. I love it but if you like driving in water I wouldn't get it because both ends have holes for cooling.
    9,245
    You should do a kv speed test with the castle link to see the free Rev
    Colorado
    292
    what's up guys
    Louisiana
    572
    I don't have a castle link
    9,245
    You should get one to tune the esc
    How does the leopard motor compare to the stock motor in size?
    Louisiana
    572
    One day. For now the internal setting mode suits my needs.
    And size seems to be about the same as stock from what I remember
    6,233
    Quote Originally Posted by 559tyler23 View Post
    It has the same diameter, but is a bit shorter.
    Louisiana
    572
    Update!
    Got my new wheels and tires in.
    Dirt hawgs on DE Trinidad wheels.
    9,245
    Looks good! Are you running the stock servo!
    Louisiana
    572
    Thanks and Yes, still stock servo lol. I need to change it. One of these days I will get around to it
    717
    those wheels look nice with those tires, how much of an offset is their
    9,245
    They look good! Hpi 2160 and dirt hawgs are 10.5" wide
    Louisiana
    572
    Just measured from outside of tire to tire
    9.75in. Didn't get a chance to run them yet.
    9,245
    That's pretty good considering the hpi are a little wide for the dirt hawgs!
    recalculating...
    564
    sorry to jack this thread, how do you like the performance of that carbon chassis? I would definitely buy one if it's quality is good. Looks beautiful
    I like turtles.
    9,245
    And big battery boxes!
    Louisiana
    572
    I'm loving it. Lots of space. I bought the revo with the chassis so I can't really compare to the stock one. You need to trim the sides though.
    Louisiana
    572
    I find the offset and fittment to the dirthawgs perfect
    9,245
    i have 3 sets! some like to complain about them!
    Louisiana
    572
    Oops, I was talking about the trinidads, lol sorry you feel that way about the hpi's when you have that many
