I plan on putting E-Revo duff's in my BB nitro Revo because they are more heavy duty. I was going to use the innards out of the stock nitro duff's in it. Do I need to use that "I" bar support for the cross pin for the spider gears?
That's what makes them stronger is that I beam!
e-revo diffs is enough to make it almost bullet proof for a nitro.
you could also upgrade to an alum cup
http://traxxas.com/forums/showthread...=1#post5342896
Heres mine mate...running them in my eSlayer, its holding up well so far. I am really impressed with them.
http://traxxas.com/forums/showthread...=1#post5333427
I'm a Rock n Rolla !
I know the I beam will give it more strength. Just didn't know if it could be assembled without it or not. Isn't the diff cups for e revo thicker than the nitro ones? That's why I want to use them.
Those links is giving me more ideas to spend more $$$$ thanks!anyways I'm going to look into these aluminium diff cases. I dont want to use aluminum cups because i read cases where people sheered the screws off in them. I don't plan on changing anything till it does break, but want the parts now before it happens. It just has to handle the power of the lrp z.28.....
If it ain't broke, fix it till it is! BB Revo
both cups are identical with one exemption, the e-revo is molded differently due to the spider pin end held by a D shape metal.
