Results 1 to 20 of 20
Thread: Suspension
    Minnesota, USA
    128
    Suspension
    Okay, so I go got my integy piggybacks, boy do they look nice! They work like crap though! maybe installer error, maybe crap parts, I got them at my own risk though.... so I need to know if I build my own with the following parts, do I or will I need anything else??
    hr piggybacks, i like the look, dont judge..lol..
    http://thetoyz.com/Traxxas/Mini-1-16...-Racing/12669/
    Springs, id like stiffer, any recc??
    http://thetoyz.com/Traxxas/Mini-1-16...Traxxas/13635/
    Shock shafts
    http://thetoyz.com/Traxxas/Mini-1-16...Traxxas/11815/
    Shock Bodies
    http://thetoyz.com/Traxxas/Mini-1-16...oncepts/12155/
    Shock retainers
    http://thetoyz.com/Traxxas/Mini-1-16...sis/GPM/12886/
    Spring adjusters
    http://thetoyz.com/Traxxas/Mini-1-16...-Racing/15660/
    frt rockers
    http://thetoyz.com/Driven-Production...uctions/12206/
    rear rockers
    http://thetoyz.com/Driven-Production...uctions/12205/
    plus bearings for the rockers and rpm frt and rear control arms and axle carriers...
    thoughts??
    so cal
    9,244
    Go for the standard hr shocks. Vxs15501 and vxs15501 .they have blue,red,silver,black .run traxxas tin shafts and blue or purple summit springs
    Rpm arms are the way to go. Theirs carriers work good when new but some have problems. I have gh aluminum and bearings for the carrier and steering post is a good idea
    Minnesota, USA
    128
    50, thank you for your answer, you think im okay to go with the hr piggy backs? i found those bodies on thetoyz.com but theyre out of stock, where do you find that you have good luck with parts? the springs youre talking about, are they specifically for the 1/16 summit or are they summit brand?? thanks again for your help!
    so cal
    9,244
    i would not get the piggybacks get the regular 15501 and the traxxas number for the blue springs is 7245 . ebay or even liquidrc.com is pretty good
    Minnesota, USA
    128
    okay so will i need any addtional hardware or parts to complete the shocks that you can tell?
    Alma, Michigan
    12,291
    I think we have gone through this before...
    http://traxxas.com/forums/showthread...010-Suspension
    And were warned about Integy:
    http://traxxas.com/forums/showthread...69488-Upgrades
    Minnesota, USA
    128
    yeah jimmie, we sure did, they dont leak though, just sag like nothing else. i took responsibility for making my descision despite recommendations. i was just trying to make sure that if i bought all of the listed parts that i wouldnt be missing anything. thanks again all for your input!
    so cal
    9,244
    The only trick you need with the hr shocks is to use stock traxxas seals and one hr seal on top
    So one traxxas seal - spacer - traxxas seal - hr seal
    Get the tin coated shafts ,blue summit springs and some 80wt oil and hr vxs15501 and 15601
    15601 for black-and-white 15602 for red -15606 for blue
    May 2009
    Edmonton, Alberta
    3,604
    do you run the stock traxxas top cap on the HR bodies? Tension ring as well?
    I feel the need to upgrade my shocks on my MERV after going BB. i have a bunch of sag on the rear as it is, so an upgrade would be nice.
    Ordered a set of HR bodies and a pack of TiN shafts. couple those with the parts from the existing shocks and i should be good to go then?
    Alma, Michigan
    12,291
    I think I should clear up the reason l linked to those posts...
    I did it so that you would not be told the same information all over again... not to be mean in any way. I realized tonight that it could have been taken with a mean tone after I read over the post again.
    so cal
    9,244
    You almost sounded jimbowise
    so cal
    9,244
    Quote Originally Posted by Cameron View Post
    Search vxs15501 aluminum caps
    May 2009
    Edmonton, Alberta
    3,604
    that's the parts i ordered but they only shows the bodies with the threaded bottom cap. What do i use up top? Or do they come with a top cap that just isn't in the picture?
    http://www.liquidrc.com/index.php?ma...t248uue5dittl6
    you meant vxs15601, got it, ordered those now as well
    so cal
    9,244
    yep i keep putting 15501!
    Minnesota, USA
    128
    thanks jimmie, i figured you didnt mean it that way. i was just seeing parts in the rebuild kits that i didnt recognize from installing and building my current set-up so i wanted to be sure that i wasnt forgetting anything, waiting for parts sucks..lol.. and thanks 50!
    Minnesota, USA
    128
    So I haven't ordered my springs yet, where do you get the traxxas ones that are stiffer, I think I've heared about a black or tan and double Black and Tan. What are the part numbers and what sites do you order these from? I figure that with even the best shocks and heavy oil you're still getting crappy suspension response with weak springs.
    so cal
    9,244
    i would go for either the summit springs traxxas #7245 or the gpm springs little stiffer . ebay or the toyz and hopmeup on ebay has some combined shipping deals
    May 2009
    Edmonton, Alberta
    3,604
    Ok so my HR parts are here, assembly is going just fine, but I'm curious what you guys have done with the caps considering the hollow ball they include doesn't snap into place like normal? In that pack there are 4 small rubber washers, i would like to think those get used as well? Cant quite figure this one out.
    Sep 2011
    Iowa City, Iowa, USA
    1,914
    will the hr shocks leak without the extra seal? i didn't get the hr seals. should i put an old seal from traxxas in and see if that works?
    1:16 Slash VXL
    Stampede 4x4 3800kv
    Rustler VXL
    May 2009
    Edmonton, Alberta
    3,604
    i built mine with a traxxas rebuild kit. the 2 part pack i bought from HR didn't have a seal. Figured i was supposed to use the traxxas top seal.
