+ Reply to Thread
    24
    Question Traxxxas Bandit proline sand paws question?
    I was wondering if the 2.2 proline sand paws
    http://prolineracing.com/tires/sand-...ck-rear-tires/
    would fit on the 2.2 proline f-11 wheels
    http://prolineracing.com/wheels/f-11...-black-wheels/
    and if there was a hex attachment to go on the bandit and fit these wheels?
    Because there is only a little bar that the stock bandit wheels fit on to.
    Thanks
    Zeeland Michigan
    1,052
    I don't think the paddle tires will fit , the wheels are offset Wheel. I might be wrong .
    1 Rusty VXL + 1 Villain EX Boat
    Grassie Ontario Canada
    2,492
    Offset rims have nothing to do about the tire fitting
    Lincolnshire Il
    37
    rhardy is right the offsets you cant use, what i used was http://prolineracing.com/tires/sand-...ck-rear-tires/ also http://www.rcplanet.com/RPM_Rear_Rev...p/rpm82052.htm I use these and hex attahcments are http://www.rcplanet.com/ProductDetai...ctCode=TRA3654 you will need to put quanity two for to put them on all four tires or just two so the paddles fit on, i use all of these parts on my bandit and everything worked fine no modding what so ever just a straight on fit
