Results 1 to 17 of 17
Thread: part #7033x
    cincinnati oh
    110
    part #7033x
    Picking up the traxxas pillow ball retainers /caps today i hear you just screw them in, thats into
    A hole with no threads. i have done that with other part so i know it will work.
    The lhs said they (traxxas) made a mistake that it was not for the stock knuckle, after thought and searching
    the net i am going for it, im calling traxxas before i hit the lh shop.
    This is the only way to clean up the slop i feel, i want to get closer to the perfect toe vrs camber angles
    And when the toe and camber have a1/4 inch slop to start with a close to perfect front end geomitry ain't
    Gonna happen.. i will post the results
    Stay warm and merry merry merry+ rc fun to all.
    Toronto
    414
    I recently installed those on my daughters mini.
    So far so good, it does elimante all the unnesscessary slop.
    Maxximumoverdrive will have more experience on that.
    cincinnati oh
    110
    Cool thanks i just talked to traxxas and they confirm that yes they self tap, so im picking them up today.
    12,291
    It is amazing to me on how many RC shops have no clue about the parts they carry.
    cincinnati oh
    110
    Just shows you need to do your homework and then do more homework.
    and if all else fails call the man...
    Pittsburgh, PA
    662
    They work fine and will cut their own threads when you screw them in. I've been using them for a while with zero problems.
    cincinnati oh
    110
    Great pic thanks, the lhs forgot to order them monday so im still waiting thanks again for the chime in.
    Pittsburgh, PA
    662
    No problem. Just make sure you put a dab of thread lock on them before you install just to give a bit more bite.
    Greenville,SC
    85
    We've been using them for a while in the stock knuckle/axle carrier. Had one back out, probably should have used some thread lock. Other than that they really help with the slop which is a problem for higher speeds.
    Richard
    cincinnati oh
    110
    What a major differance that made ..... till i slammed a solid chunk of concrete and broke a knuckle
    but it ran much straighter and did what i asked it to do, the crash was a bad eye problem i have,
    awaiting surgery on that, off to the lhs for new knuckles.. thanks again
    oh and so easy to install im happy happy happy......
    cincinnati oh
    110
    Went with the rpm knuckles for the front i do like them better but only time will tell
    canada
    41
    how do you take the stock ball caps off ?
    cincinnati oh
    110
    Quote Originally Posted by Demigod15 View Post
    A small flatblade can b used jst push in the tab and the retainer will pop out do the same on the other side and out it comes
    canada
    41
    what is a flatblade ?
    Rotterdam, Netherlands
    7,401
    A screwdriver.
    cincinnati oh
    110
    Yesssssssssssss
    cincinnati oh
    110
    Ps. Count your turns if you remove the pillow balls helps to get the camber and toe close that is if u remove them.
