Waiting for a chassis LOL. I'll probably get mine before you and you ordered it a month ago lol.
1/10 Rally x2/P4de/P2de/Rustler x2/KB Rally
^^^finally got your chassis and putting it together? red
NOOOOOOO!!! I called TRAXXAS, they said, well, we got some in the other day, you should get yours soon......
If I dont see it monday from the LHS, I'm ordering straight from TRAXXAS - GRRRRRRRRR
"Red"
"Who wants a Rod that you cant Mod?!"
order me this today http://www.ebay.com/itm/Hyper-10SC-C...item1e6fbca4ee
Nice, that's a good motor and esc. You see the waterproof Mamba Monster 2 is now out? Same with the waterproof Sidewinder 3 (just like the flux vapor). I am ordering up the Sidewinder 3, and a mamba monster 2. Now the question I have, anyone know of any MMP waterproof in the works? I looked at the site and don't seem to find any info. If they are coming out with them, looks like I will have about 6 mamba max pro's for sale here and replace them all with waterproof versions.
Peter, I assume you're not married.....if you are....how have you convinced her to let you spend all your money on RC????
I really need to know the secret! My "Honey hole" has dried up!
"Red"
i'm married with 2 kids (4yrs & 2yrs) lost our house alittle over a year ago so big bills are out of our shoulders, so i have few $$ to spend and with my overtime from work that helps alot.
I installed the Slash Ultimate GTR shocks & Traxxas aluminum bearing carriers and c-blocks. Fixing to head out and run the Rally, EMBE, and the little guy is going to drive his MERV.
Rudeness is the weak man's imitation of strength.
Those are the stock a-arms. I'm fixing to go run the car. When I installed the carriers I pulled the cvd out on the passenger side back and the spline was pretty long. Just figuratively speaking at least ½" or more. I can get you a hard measurement later if you'd like.If these stock a-arms ever break i'll prolly put RPM on there. I'm thinking these are going to last me a little while. LOL
The spline is 17mm long. They look to feed right into the thick shaft fully and maybe a couple of mm more inside. So i'd say you probably have at least 10mm to play with and be ok. I'd feel way more comfortable with 5mm though. LOL
Here is a pic of the spline laying on top of the half shaft, close to being where it would insert inside.
Hope this helps ya my friend.
recieved my rc-solutions extended aluminum arms, needs two more.
The little guy and I went out bashing at the school after lunch today. I took the Rally & ERBE for me and him his MERV. About 20 minutes into the run he was WOT and ran smack dab into a hurricane fence post. It split his car in half.He was so upset. I had to calm him down and tell him daddy will get it fixed. About $20 worth of parts and he'll be back on the road again. He needs a New Front Builk & Chassis.
I ran 4 packs through the ERBE and a 3S pack in the Rally. Fun times.Came home cleaned all the cars up put them back in their spots.
I just now located the optional 19t pinion and installed it on the Rally. I thought I had a 20t but cant seem to find it. 19 will do me just fine. LOL This is a bump up from the 17t I had in there. I may also have a 52t & 50t spur, this won't really do much on speed but will give me room for if I bump the pinion more.
I was thinking about possibly bashing the car tomorrow but the weather is supposed to be funky so think they will stay at home where its nice and warm. LOL
I soldered up my Novak HV 7.5 turn 550 motor to use it with an HPI branded mamba max pro and realized I suck at soldering. Regardless I got the job done. Then I realized I have the esc wired for two batteries so ill have to desolder and resolder or hunt for an adapter.
Just make a jumper plug out of an old battery plug. Wire both tab's together and slid tab's in plug.
Installed the aluminum bearing carrier. Receiver is due tomorrow, then just need to order some lipos and the Rally will get run for the first time
So far it is the aluminum bearing carrier, aluminum shock caps (I have some D8 shocks I may put on) and Traxxas 17mm hub adapters. Castle sct v3 esc and Castle 3800kv motor. Control is from a Futaba 3pks.
I was building a 1/8 track in my backyard, but the surface isn't really cooperating lol. So, I think I am just going to build a multi surface rally course.
Cheap, Fast, Reliable. Pick 2.
nice badaml, i also received some parts off the mail today.
Proline shocks, esc fan love this new car and the power slides
Shocks handle a treat
Stampede 4x4 basher
Rally 4x4
Got some new street and off road tires, I should have ran it but I am too much of a whimp to go out in 50 degree weather.
DJ
Rustler,Slash 4X4, 1/10 Rally
Installed new spring's, RPM shock guard's, installed new traxxas cvd's, Made plate to hold MMP esc, installed new street tire's and 2400 castle motor. Oh the extended battery box as well. More to come sunday and monday.
waiting........
"Red"
aluminum bearing adapter for the slipper the plastic one was melted like a pancake looked like a washer where it meets the bearing, and yes i changed out bearing. RPM body savers to front. also got some street fighter tires as the OME one are about gone. Looked for a Ford focus body but will have to order from the states
Stampede 4x4 basher
Rally 4x4
The Turkey has arrived. Now I still have a few surprise's and other part's to add but I figured What the heck, show it off.
I still need to wait and see how the spring's settle as it sit's really high. I run it a few time's and see if it soften's up a bit. Dampening feel's real good F/R. I do need tp cut just a few MM's from the front of the rear wheel well and a tiny bit off the rear of the front wheel well.
Setup.
Castle 2400/mmp
Revo spec slipper
18/52 gearing
Traxxas cvd's
SupraSale's Street slick's
Gravedigger spring's
green wheel nut's
battery expansion kit
RPM led light pod
Traxxs aluminium bearing adapter with Boca yellow ceramic bearing
a few more item's will be added when they arrive. And the wire's will be cleaned up. Let me know what you'll think.
http://s509.photobucket.com/albums/s...view=slideshow
Installed the following:
-TRX aluminum castors
-TRX aluminum front carriers
-TRX aluminum rear carriers
-Big bores
-Centre diff (filled with ofna diff lock fluid)
-Sway bars
-Integy 17mm adatpers
-GRP Belted radials
Im placing my order for a "dusty motors" chassis cover. If you guys havent seen these, they are like the outerwears but BETTER. They actually HAVE the cut out for the nerf bars pre-sewn into them AND they include a zipper the whole way along the top so you can leave the cover on while changing packs and turning the car on/off. Theyre about $35 shipped... ive got one coming for the rally (slash 4X4) and my ERBE.
Pede, Summit,
ERBE, Rally,
Motley Crew, 1SQ
I have heard of them, but did not know they had one out for the rally yet. Interesting.....
Pave the dusty motors looks good order one as well
Stampede 4x4 basher
Rally 4x4
recieved my rally chassis and tall battery hold down. chassis is for my spare or maybe build another rally stock spec.... i dont know yet hahaha..
Here are a couple pics of the 'Dusty Motors Shroud' on my Slash 4x4. It does come with a zipper top, elastic for the front and rear openings, & a couple cuts where it velcro's to the chassis. I'll slap it on my Rally this evening and see if it fits any better than the Outerwears. I think I tested it already but can't remember LOL. It's a nice shroud but not sure its as durable as the Outerwears. Time will tell. On another note I do have the DM shroud on the MERV and it has done a fantastic job as that is the onlly solution for it.
Here are the pics.....
....Hope this helps with anyone that is curious.....
Got tired of waiting so I dismantled what I had built and started to set up my Stampede build on the slash chassis. Called TRAXXAS this morning and found all the parts and chassis instock and order through them direct.
SOOOOO, now that I have my chassis on the way....again....I guess I'll have to go back to that project.
I'm so confused right now
"Red"
"Red"
Got my birthday present last week,. Added big bores, vlx system, and spec lipo all off my flm pede. Sorry pede. Added some anaconads off my rusty and I'm almost ready to test it out once it stops raining.
JConcepts over tray ordered
Jconcepts Rulux wheels with Proline Knuckles installed![]()
its late and i just order the tekno cvd's set F/R. could'nt sleep thinking about it LOL.
Haha....Now that you said that it does doesnt it?! LOL When I take my RC's to the track they always want to look under the hood.....I tell them its 'The Wraith'.
Nice, very nice!! I run Tekno, MIP, & Traxxas CVD. I like the Tekno by far the best. Especially their oversized bearing in the rear carriers.
