Page 16 of 30 FirstFirst ... 6141516171826 ... LastLast
Results 601 to 640 of 1174
  1. #601
    Long Beach, California
    6,630
    Quote Originally Posted by ViperZ View Post
    Looks like a nice piece. The segmented assembly is like the RPM one.
    Yes it does . My mind is already thinking of rib the edges, I have some left over XO-1 chassis from building my 1/8, so that should give some more strength.
    | Rally GT8 Powered By CC | BackSl4sh Roadrunner |
  2. #602
    Glens Falls New York USA
    653
    Keep us posted on how you like it. I got the rpm bulkhead because iv had nothing but trouble with HR stuff.
  3. #603
    6,630
    Quote Originally Posted by CoreyM View Post
    Sure will bud I can't put them together now, still waiting on strc bellcrank. I like how the arm pins fit very snug without any play.
    Quick question on the strc, do I have to use the servo saver spring from the stock bellcrank? and how do I take it out? Lol.
  4. #604
    653
    Ya. You use the stock spring. When you remove the front bulkhead and disconnect the servo you will look down at the stock bell crank. There will be 2 hexs that you remove. The bottom part of the bell crank will slide up and off the post. Can be tight fit. I'm haveing some issues with my strc bell crank and have asked for help in the slash 4x4 section of the forum. There's some good info there you should check out. Don't over tighten from what iv read. This might help.
  5. #605
    6,630
    What I'm having problem taking out is the actual spring, I never took one out yet lol.
  6. #606
    653
    Remove that hex nut on the left and unscrew the round piece on top of the spring. The stock one snaps on and off if I remember right. Where the strc screws on. So if you can't unscrew that piece then it pops off and then you can remove the spring. If you look at the crank on the left you can see tabs coming up that let that round piece to pop off to remove the spring.
  7. #607
    6,630
    yeah I can see it snap right on, I even push it down and I must say that spring got a good tension lol. do I have to take the bearing off first?
  8. #608
    653
    Ya. Take the whole thing apart bearings and everything. You will either be transferring it over to the strc or discarding it to the spare parts bin. I'd wait to take it apart until your strc gets to you so you can look at it complete and remember what your doing. Strc does not provide any directions. And if your burnt like me you will forget how it goes back together. Lol
  9. #609
    6,630
    hahaha, I was just in the garage to see if I can take it apart by taking the bearing off and the plastic piece flew off lol. thanks.
  10. #610
    Jul 2013
    Saskatoon, SK. Canada
    2,160
    It comes apart really easy. I compressed my OEM springs in a vice to reduce the required load on the assembly. I did this for all 3 of my cars with the STRC bell crank.
  11. #611
    6,630
    Yeah, I can take apart iust about any other parts of the car but the steering assembly got me scratching my head lol.
  12. #612
    May 2013
    Uk
    742
    I followed viperZ tip on compressing the spring.....it works a treat.....
    Ps....just finished reading your thread....great work you have done humay..very classy stuff.....keep it coming
  13. #613
    6,630
    I know ViperZ will drop by and give me his tip on how to along with others,
    Thanks simon, I appreciate it
  14. #614
    Jul 2013
    2,160
    Quote Originally Posted by simon32man View Post
    Good to hear Simon!
  15. #615
    Sweden
    408
    also they didn't have the lip as it meet/contact to the chassis
    compare to stock
    what I like about it is, you can take it apart in two pieces, so the steering bellcrank stays in.
    I think Traxxas has a better fit to the chassis than RPM...
    But RPM still good...
    Rally
    Slash 4x4 Platinum x2
    Stampede 4x4 VXL
  16. #616
    6,630
    I have to agree, nothing like the stock fitment. I might grab the RPM later
  17. #617
    6,630
    received my tekno M6 dogbones and noticed the end pins are rounded than the old ones, take a look.
    old left/new right
    still waiting on my STRC bell crank, its scheduled to be here today but I guess it'll be here tomorrow.
  18. #618
    6,630
    got my STRC bellcrank today. hope this pictures will help to someone that are having trouble installing it
    came nicely pack
    individually pack to prevent from getting scratch
    out of the bag (minus shoulder screws and bearings)
    make sure to line up this part (pointed arrow)
    here's a comparison with stock
    next drop the tension spring in place
    next the treaded collar with lip facing down
    continue to next post......
  19. #619
    6,630
    not sure how much tension, so I lay it down next to stock and base it from there.
    next put the bearings at each end
    next...drag link, put a small dab of blue Loctite.
    STRC include 2 stainless steel screw to secure the top bearing but its Philip screw head, so I decided to use the stock ones
    turns out the stock head screw hitting/binding the chassis so I opted it with round head screws
    just when you think your done LOL
  20. #620
    Jul 2012
    Mesa az
    373
    I hate when I do that.
  21. #621
    6,630
    Quote Originally Posted by Wakesurfer98 View Post
    yeah, I was too focus on getting it done right, then next thing you know you forget one thing
  22. #622
    May 2013
    Uk
    742
    Ooops.....Lol....well documented...good work humay
  23. #623
    653
    Great write up. Thanks. I used the stock screws as well instead of the ones that came with the strc bell crank. I'm going to switch them out and see if that solves my issues. I'm using mine on a HCG chassis that I'm having the problem on.
    P.S. Your not supposed to tell anyone when you do that.
  24. #624
    6,630
    hahaha its fun to tell your mistake sometimes, put you one step down from being perfect but then again everybody makes mistakes
  25. #625
    Jul 2013
    2,160
    Good thing it's just RC cars, where it's easy and simple to fix the mistake
  26. #626
    6,630
    looking at the X3 body, I got to think,....what if I make the hood scoop for air duct to cool the motor off so, I come up with my spare XO-1 air duct.....cut to contour from the inside.
    as the air enter and exit from the inside.....with the curve side, air will travel downward right above the motor.
  27. #627
    Jul 2012
    SoFLa
    98
    I had to look a half dozen times, but then it struck me! So sorry to laugh, but I commend you for being honest!
  28. #628
    6,630
    Quote Originally Posted by CrashTestDummy View Post
    None taken man, we all have our moments
  29. #629
    6,630
    My hood scoop duct, here's what it looks like now......
    peeking from underneath
  30. #630
    Jul 2013
    2,160
    Looks like the hole needs to be bigger to be effective
  31. #631
    6,630
    yeah I got it bigger now, cut some more side to side, with the air compressor and my hand inside the opening, I can feel air coming in .
    before
    now
  32. #632
    6,630
    tested my air scoop, run it for about 5mins (no full throttle but lots of braking), temp outside around 75* (much better than the past few days heat 97*)
    didn't use my temp gun, test it by touch and I must say its cooler than those other runs . need to do more test run to see how the body act at higher speed.
    good news: I just look at my tracking # of my 2650 motor I order from Hong Kong has arrived in US land.
  33. #633
    May 2013
    Uk
    742
    Great air scope mod....This is pretty serious stuff
  34. #634
    Jul 2012
    SoFLa
    98
    The scoop looks great! And I love the fact that you were able to cobble it together with a part that has the Traxxas logo...sort of pays homage to your cars' roots and how far you have been able to take her!
    Last edited by CrashTestDummy; 05-05-2014 at 11:22 AM. Reason: fixed grammatical error
  35. #635
    6,630
    thanks simon
  36. #636
    6,630
    thanks CTD gotta love traxxas
  37. #637
    Nor Cal
    487
    Awesome! Can't wait for the review. For $40 I hope its good. I would be very interested in getting one too.
  38. #638
    6,630
    Quote Originally Posted by RadReptiles831 View Post
    Yeah man, it should be here Wednesday or Thursday.
  39. #639
    6,630
    I got my motor today, here it is..
    Features:
    •Pole 12 Slot Hi-torque Motor Design
    •CNC Machined 6061 T6 Billet Aluminum Heatsink Can
    •High Purity Copper Windings maximizes Efficiency
    •High RPM ABEC5 Oversized Bearings
    •Universal fit, fits all 1/8 brushless cars-multi-mounting system for M3 or M4 screws
    •Precision balanced rotor, smoothness for best reliability and maximum RPM
    •Stator-Super Thin (0.2mm) Laminations
    •Removable/Replaceable Rotor
    •Precision Engineered for Maximum Energy Conversion
    •ROAR Legal
    what surprised me was it come with 10awg (its says 12awg on their site) wires and already soldered with 6.5mm to fit MM ESC
    here's a comparison with my CC 2200
  40. #640
    Jul 2013
    2,160
    Looks good, and a like a beast
    I just got back from a maiden running my Rally-2. While working on pictures it was good to see this beauty!
