Results 1 to 10 of 10
Thread: Tbone bumper ?
    13,273
    Tbone bumper ?
    Do you need some of the stock ft bumper parts to make this work?
    Mounting it directly to the front skid, there is nothing to hold the suspension pins in.
    Jul 2012
    Nowhere, Québec, Canada
    400
    Everything from the stock bumper have to stay in place. You just need to put the bumper over everything....
    As you see in the second pic, I had to dremel a little bit the bumper because of the shock guards....
    13,273
    Cool! Thought I was goin crazy lol...
    Jul 2012
    400
    Lol.... you also would like to get longer screw, I just bought 4x14mm and 4x12mm flat head screw (I'm not sure enough which ones you'll need.)The one I got weren't long enough.
    13,273
    If you mean the 3 countersunk screws under the tb bumper, I gotem. I am gonna use sway bars. Need to figure out how to make them work with the shock guards also.
    Jul 2012
    400
    yeah, that's what I meant, about the three countersunk screws.
    I don't have sway bars, but I think they might replace the little plastic spacer over the screw that hold the shock guards...
    I'm just saying that from the pic I've seen because I have no idea ;-b
    13,273
    If there is a spacer, then it should work fine, as long as there is no binding, just have to use hollow balls instead of the sways ball ends... I thought about not using the shock guards, but there is not much kick up in the front suspension, leaving the shocks and sway ends in harms way...
    Jul 2012
    400
    Just found something that might be interesting for you:
    Hot Racing sway bars without losing the shock guards
    Pop out the ball end and use hollow balls from a E-Revo.
    13,273
    Haha. I have every Trx hollow ball known to man... I can make it work. Thanks for the pics...
    Salisbury, NC
    633
    I'm running an RPM bumper and sway bars, with 3.2 rims with big tires. Had to do a little "Dremeling" on the shock guards, but you can make it all work together.
