    35
    Stabilization System Reset
    What am I doing wrong I've watched the video half a dozen times but I can't get the QR-1 to go into calibratin mode. Currently trims are all the way out to 25 and still won't really hover. Help
    midwest
    303
    You have to move the right stick left and right very fast with the left stick held in the lower right position for the lights to blink...
    Also, if you have been flying it around at all, you will have to disconnect and reconnect the battery again.
    29
    Make sure to take the trims all back to zero when you do the reset. Otherwise the quad will veer off in the opposite direction from what you were trying to trim out.
    29
    A little trick....... When doing the reset, put the controller in Expert Mode. It works a lot bettering when moving the sticks back and forth!!! I was having issues getting mine to reset and I was thinking maybe there just isn't enough throw in low-rates. So I tried it in expert mode, more throw, and it works every time and quick!!
    Hope that helps.
    62
    +1. Mine will only reset in expert mode.
