Results 1 to 10 of 10
Thread: Rear toe
    219
    Rear toe
    For raving purposes is it better that the rear tires are toe in? I swapped the spindles from side to side to make them straight but I'm just wanting to know which way is better for the track
    El Sobrante, Ca
    7,058
    You must have the Ultimate edition! The toe in helps it track straighter. I believe it helps in racing, someone else should chime in that has racing experience.
    Oct 2012
    110
    toe in=stability
    toe out=faster turning/less stability
    219
    Also what do you guys like better for the track slipper clutch or the center differential? And I have a slash ultimate
    Oct 2012
    west virginia
    37
    swapped spindles?? can you explain??
    219
    If you switch the rear spindles from left to right it will get rid of the negative toe on the rear end
    Oct 2012
    110
    let me clarify...with the slash ultimate edition, the rear spindles come in different colors. they change the angle where the pin goes through at the bottom.
    the stock ones we normal people buy are not side dependent or adjustable, theyre both perfectly symmetrical, so swapping wont do anything.
    El Sobrante, Ca
    7,058
    He is talking about the rear hub carriers. On the Ultimate and Platinum they come with a lot of toe in. If you switch the side that they are labeled for there is a lot less toe in.
    Grassie Ontario Canada
    3,134
    Quote Originally Posted by Oldblue72 View Post
    if you have the ultimate you should have both...
    go with center diff and swap oils if you feels accelarations to slow
    Aug 2012
    Central NJ
    1,245
    Toe in is essential on any RC truck.
    It stabilizes the tracking of the truck under acceleration. No toe in and you get horrendous torque steer.
    For racing the center diff hands down, it allows you to power out of turns without the rear end coming loose and passing the front end. For bashing its up to personal preferences. I keep the center diff in most of the time.
