Results 1 to 12 of 12
    36
    Rustler VXL tranny issues???
    Well, the last time I ran my Rustler it got stuck under a branch and I tried to power out of it (stupid, I know). Now, this is what I get, my pinion and spur are okay I think it might be something wrong with the tranny. here's a quick 40 second video to help. Thanks!
    http://www.youtube.com/watch?v=oB3FJhEgT0Q&sns=em
    36
    How would I go about fixing this?
    Port Alice, BC, Canada
    1,128
    Take it apart. Sounds like the slipper shaft pin broke. Easy fix. If that is not the case. Look over all the gears.
    1/10 Rally x2/P4de/P2de/Rustler/Sl4sh MT
    36
    Is it a quick fix?
    1,128
    Not bad, I can do it in about 20minutes if that. If it's your first time taking it apart it may take longer. But, it's the best way to get to know that rear end and the transmission internals. I used to steer away from opening that part up and was kind of scared to. Now I could do it with my eyes closed and it's extremely easy. Part is about $2 if it's the slipper shaft pin.
    Part #3793
    Take it apart bud, and let us know what it is
    http://traxxas.com/products/models/e...rvxl-downloads
    Check the link above if you need to download the exploded views.
    36
    Is this it? I don't see anything wrong
    [IMG][/IMG]
    north van canada
    528
    Is the pin still good it holds the gear on the shaft if its broken I used a piece of a Allen key and some ca to hold it in worked for me
    Powered by Castle
    South of St Louis
    5,986
    I don't see the pin on the shaft.
    1,128
    Neither do I, hard to tell. Actually if you look close you can but from this pic it looks sheared?? Jaime? In the groove on the idler gear towards the shorter end of the shaft in the pics, should be a pin kind of like the pins in your wheel hexes. Is that broken, snapped, missing?
    36
    It looks fine
    Newton, KS
    68
    Maybe slipper pads and/or disc is worn or glazed over?
    Feb 2008
    Fl
    3,062
    post up some pics of the rest of the gears in the case so we can see the mesh, also check the gears in the diff those have been know to break.
