Results 1 to 10 of 10
Thread: Stripping sound
    56
    Post Stripping sound
    I have had my mini e revo for about 2 weeks and there is a sound like the gears are being stripped. I have checked the spur gear and there is not stripped teeth. I have tried opening the main gear inside but it is attached to the driveshaft underneath the e revo and I can't figure out how to take it apart. Help is appreciated!
    16
    it is probably your diffs. Kind of a pain unless you enjoy that kind of stuff like me. It does help you learn about how the car works and allows you to more easily diagnose and solve your rc problems. Here is a video on how to take out your diffs.http://www.youtube.com/watch?v=PFt1cWpbFn4 that was just a quick search, you can find a better video if you search on the tube a little. I would recommend that you refer to squirrelod's videos that he has on the mini revo. He is very thorough and knowledgeable.
    9,245
    you will need a few packs of associated 21141 for the shims and this from jimmie http://traxxas.com/forums/showthread...-your-bulkhead
    56
    Dayum... This looks pretty tricky. I'm a heli flyer not a truck person so it's all new to me.
    56
    How would I know if it is the diffs that are causing the problem?
    St. Louis, MI
    8,162
    If the sound is being produced upon acceleration or deceleration, it is probably the differentials.
    If you go to the product page of your RC, and then to the download section, you will find exploded views that are helpful in finding out how to work on your RC.
    56
    The sound is from acceleration. Braking is fine.
    St. Louis, MI
    8,162
    Quote Originally Posted by B3NNZ View Post
    It is time to print the exploded views, grab some tools, a couple of baggies, a marker, and some patience.
    Pull the rear differential apart to inspect before you order parts!
    I suggest pulling the front apart too...
    Pull it apart, using the baggies and marker to indicate where parts go and the exploded views to confirm.
    9,245
    Then its the rear diff
    169
    Mine is making a stripping sound but they aren't slipping. I shimed the diff and confirmed it wasn't slipping. Spinning by hand it would make the same sound and I could see the gears. I cleaned the groves of the gears and the sound went away. I think I got junk in the diff.
