Results 1 to 2 of 2
    Oct 2012
    110
    transmitter/receiver problems...help diagnose which is bad
    i have the 2.4 tqi stock setup and i have no throttle at all.
    i was trying to set my throttle end points on the transmitter...i dont know what/where i screwed up but ive lost throttle.
    i defaulted the transmitter 3 times and still no throttle response. at first i was blaming the esc/wiring but i swapped throttle for steering and throttle worked with steering but steering did not work with throttle.
    so, ive defaulted the transmitter, reset the end points, defaulted the end points etc etc...
    im also testing the receiver using my vrc pro usb adapter on my laptop. steering works fine but 0 throttle response.
    how can i tell which of the 2 parts is bad without buying/borrowing one or the other?
    Oct 2012
    110
    looks like ill be buying a receiver and see what happens...
