Results 1 to 3 of 3
Thread: diff seal?
    Jun 2013
    LaConner, WA
    214
    diff seal?
    Okay, car is relatively new, has enough run time to be broken in. It is not abused. Yet. I pulled the rear diff to shim and all the diff fluid was in bulkhead. I had no issues other than handling started to go away...So I put 1 shim and thicker fluid in after cleaning. The 3 screws seemed to be where fluid came out of. So I dabbed some blk rtv on top and bottom hoping it would help seal. Now I pulled front bulk head and same scenario. So I am going to give it the same treatment.
    My question is, what do you do to get a better seal on diffs?
    Iowa City, Iowa, USA
    1,887
    I think it is supposed to leak a little bit. As the oil heats up during the run it expands and has to go somewhere. Maybe try using associated green slime.
    Sent from my SCH-R970 using Tapatalk
    1:16 Slash VXL
    Stampede 4x4 3800kv
    Rustler VXL
    Apr 2013
    Poland
    176
    did you inspect the edges? It could be slightly damaged in one spot and that would cause leaking
