i have my shocks in the middle up top and the middle on the bottom, i want my truck to sit low, including the suspension, so is there any way i could do this without touching my shocks, or is my best bet to go inside up top and out side on the bottom with the shock mount holes? also, do rpm a-arms help to lower the body as far as shock mount positions go, for instance, if i had on stampede with stock a-arms and one with rpm arms,same shock mount position on both, would one be taller or shorter then the other??????in general i dont want that much ground clearance, with a low CG!!!
