Hi All,
just had a high speed stack with my Slayer Pro and it did a few cart wheels down the asphalt road, now i notice one of the rear wheels has a wobble about it, just like you see lorry's from time to time.
I'm assuming I don't need to adjust the toe in or out, but I have no idea what is bent/broken to cause the tyre to do this.... any suggestions on what to look at? I don't want to leave it like this as i think it will cause the tyre to scrub out early.
Cheers
Try swapping parts off of a un-damaged axle, and find out what parts you can swap out could make the problem stop. Good luck, Hope this helps!
