    Frisco, TX
    389
    10 min Tire Balancer
    Hey guys, just wanted to promote the benefits of balancing your tires. Tire balancers cost a little more than I'm willing to spend, so I built my own using a 1x4, aluminum L-bracket, and an old erevo knuckle. The only money I spent was on the ceramic bearings I put in the knuckles. You don't need ceramic bearings...but I wanted it to be as smooth and accurate as possible. The bearings cost $10. It took me 10 minutes to build.
    9,244
    looks good ! i made one with a long bolt and some bearings (t maxx bearings fit right inside the rim ) and plastic bushings .spins good works fine!
    how do you calculate the weight? i have putty balance it then weigh the putty and cut the lead tape
    Frisco, TX
    389
    I just keep adding modeling clay until it's balanced... Nothing fancy like lead tape, but it works.
    Apr 2007
    Valrico, FL
    1,679
    Nice job! I did something similar a while back using a spare carrier, but I just attached the carrier to a piece of 1x3 and clamp it on the edge of my table.
    -ERBE
    -Slash 4x4
    kansas
    7,821
    looks like it will work well with larger, wider tires too.......
    one of my fav balancers...
    http://traxxas.com/forums/showthread...wheel-balancer
    Long Beach, California
    6,243
    ^^LOL blocks. i might steal some from my son's toy box.
    | Rally GT8 Powered By CC |
