    Brookline, NH
    1,199
    Blinking red and green esc
    Why is my mmm esc blinking red and green on partial forward throttle? Isnt it suposed to be just green?? in reverse its just red.
    9,244
    12. What do the flashing LEDs mean?
    The LEDs can have different meanings depending on what you are doing.
    If you are not calibrating and have no throttle input:
    Flashing Red and Yellow = over temp
    Flashing Green and Yellow = low voltage cut-off(battery)
    Flashing Green OR Red = Speed control has not been calibrated and is not armed; or throttle sub-trim is not at 0.
    Solid Green OR Red = should not happen when at neutral, indicates full throttle/reverse
    Flashing Yellow = possible problem with controller
    Solid Yellow = indicates neutral and armed
    Flashing all colors = speed control is not receiving a valid signal from the receiver, usually indicates the receiver wire is plugged in backwards into the receiver; possible problem with controller or with throttle channel on receiver.
    If you are applying throttle or reverse when NOT calibrating:
    Flashing Green OR Red = indicates partial throttle (green) or reverse (red)
    Solid Green OR Red = indicates full throttle (green) or reverse (red)
    Solid Yellow = should never happen
    If you are applying throttle or reverse WHEN calibrating:
    Flashing Red and Yellow = should not happen when calibrating
    Flashing Green and Yellow = should not happen when calibrating
    Flashing Green OR Red while beeping = indicates speed control is looking for full throttle (green) or full throttle (red). If it continues for more than ~ 8 seconds, indicates speed control is seeing partial throttle (green) or reverse (red), increase endpoints on transmitter so speed control sees full throttle/reverse.
    Solid Green OR Red = indicates full throttle (green) or reverse (red) has been read
    Flashing Yellow = speed control is not seeing a valid neutral signal, check your transmitters throttle sub-trim is at zero, exponential is set to 0 or linear, and mixing is disabled.
    Solid Yellow = indicates neutral has calibrated and is armed
    Flashing all colors = speed control is not receiving a valid signal from the receiver. Usually indicates the receiver wire is plugged in backwards into the receiver; also happens when speed control has accepted a calibration setting (throttle, reverse or neutral) and flashes/chimes 4 times before moving to next calibration point; or problem with throttle channel on receiver.
    Brookline, NH
    1,199
    I have that info too. But no where does it show flashing green an red with partial forward throttle
    Brookline, NH
    1,199
    Guess i will have to wait and call castle and see what they say.
    Brookline, NH
    1,199
    Got it figured out. Had the motor test box checked in the castle link program. So i guess the esc was in motor test mode or somthing. I Downloaded the latest firmware and recalibrated now only green light in forward
    9,244
    Good thing you didn't floor it !
