Thread: Summit Rebuild
    Aug 2012
    Alberta Canada
    894
    Summit Rebuild
    Well after number 3 dead traxxas servo I will never use them again, I was at a hobby shop not long ago and I seen a Hitec HS-22MG It is a slightly bigger servo but I thought why not try it, I got it cheaper than the HS-85MG which I will probably use if this one never worked.
    So after some dremeling I got it in there, I almost got carried away but its hard to get in such a small place.
    But here it is.
    I didn't have a chance to try it yet, I'm Rit dying the chassis yellow and I have some GH axle carriers to go.
    I'm also going to try the pro line dirt hawgs, see how some firmer rubber handles.
    79
    Your servo horn's and steering link's positioning looks totally wrong on your second pic, you won't be able to steer both direction with that setup. It should look like this.
    Aug 2012
    Alberta Canada
    894
    its not staying like that. I was only test fitting the servo, I'm stripping it down and dying the chassis yellow.
