Results 1 to 15 of 15
Thread: esc issue
    12
    esc issue
    Has anyone had there castle esc switch fail on them ? I bought my e revo brushless brand new 8 months ago and didtnt use it too often, i used it like 6 times in lots of dust/dirt area for bashing and a while after useing it i couldnt get the swtich to turn on at all, i kept having to try it many times switching back and forth till it finally turned on and worked perfectly runs great but almost all the time now i cant get it to turn on without trying it back and forth for a while. i ran 4s lipos in it mostly the traxxas 25c 2s 7600mah sets and it had so much power on those. i sent it to caslte last week and they told me it might be a wire or switch going out on it when i called before i sent it in. i wonder why though i never beat it too hard. so im just waiting to see what castle tells me when they call me back.
    BNE
    637
    Have had ESC switch fail too. Just cut it out and bridged the wires and have had no issues since.
    Always get a 2nd Opinion!
    12
    some else told me the same thing to bridge the wires so i dont have to have that switch issue occur anymore thanks for the help
    kansas
    6,396
    when you call Castle that is one of the first things they tell you to do if the ESC doesn't turn on.
    cut & bypass the switch....
    Will not void the warrenty....
    4,768
    i got a question if the switches cause this so much why put them on in the first place? i would think it would save a little cash from installing them the switch, wires, solder wires for it right? maybe the new MMM 2 wont come with it.
    DEU 8:18 ESV
    UNknown
    4,283
    eliminating the switch is the right thing to do. mine still there but i dont turn it off from the switch....... i do it straight thru the batts by unplugging it.
    3,065
    Yip, I have...twice...bypass the switch...read post #16...thats what I did...I have never had nay issues.
    Rock n Rolla !
    12
    thats a good idea to have the wires together so when u plug the batteries in its on and no more hassel of dealing with the switch not working. i just hope it doesnt happen again or else i will go that route, i got 2 mmm one a revo and other emaxx
    kansas
    6,396
    it is a little hard on the caps not having the switch.....from a very old thread...
    Central NJ
    1,245
    I have had one outright fail and another that the solder connection on the switch was bad. I dont like running without a switch as stated its not good for the ESCs components and I like being able to switch it off in a hurry if I need to instead of having to pull the battery connector. Best remedy I found is to ditch the slide switch and buy a radio shack special single pole single throw mini switch to replace it.
    13,573
    Don't the caps charge regardless of switch position? How is the lack of a switch more damaging?
    Edit: food for thought...a little while ago Castle was sending back refurb Monsters with the switch removed.
    kansas
    6,396
    this is the thread I was thinking of..... but it was not what I was thinking.... catch any of that......explain it to me please...lol
    http://traxxas.com/forums/showthread...ghlight=switch
    13,573
    Well if you find anything else please post it up. I'm no electric guru like BrianG and the questions I posed above were not rhetorical. If there really is a greater likelihood for damage, me and my 3 & 1/2 year old ERBE want to know.
    Back OT: my switch finally failed in the ON position. I have not bothered to replace it.
    South of St Louis
    5,203
    This is the best scenario. Mine broke off in the on position so I left it that way. Now it's flat and doesn't get bumped off anymore.
    Deer meat in the freezer
    kansas
    6,396
    ksb its not what I was thinking, not even close......he is talking about a...........
    You aren't supposed to use a pre-charge resistor on any of the Mamba line of ESCs.
    a resistor that is added to help with the spark when you plug in the batts...........
