Hey 50, what wing mount you thinking of?
Always get a 2nd Opinion!
50 : Tekno R-C Maxx Wing Mount will fit with somes modification, mine is hook with Integy Shock tower but I have to shim it!
Bones Crusher said... Bite The Dust
Yeah, that's what I found too. I have the FLM shock Towers and the Tekno Maxx Wing Mount can be made to fit with some mods.
check out my Road Maxx - Street Warrior post :P... a couple of pics here
Hot bodies 67521 mount with a proline 6024-03 wing
Nice...should look good mate.
Rock n Rolla !
i shimmed my servo saver but i think i am going to replace the shims with teflon washers for less friction
Hey 50, what Steering System you running, still stock or have you upgraded to Aluminium?
I went with the gh bell crank. I tried two shims to take the slack out but was still metal to metal. I just shimmed it with one traxxas teflon shim on each side. They are 6mm little big but should be better then the metal ones. Think they are 6x8x.05mm
Thanks. I also have upgraded to Aluminium (forget the brand) and have noted some slack in the system where the main "dogbone" arm attaches. Am going to look into some shims too.
Check these out . ok not 4mm 5mm! http://www.ebay.com/itm/TRA1985-Trax...item2ec6d80540
Thanks for the info. Will get some of those.
I am putting orange seals ceramics in the carriers in my revo so that leaves my yellow seal ceramics to go into the maxx!
Just another product with no bolts or instructions!
Good thing I have a good supply of bolts !
Keen to see a pic once mounted to Truck if possible please. Thanks.
I turned the top bracket around and have to decide how I am going to install it. The shock tower mounting holes are threaded which is fine for the lower holes but the upper bolt has to go through the shock tower into the wing mount
Holes lined up and drilled![]()
Didn't want to do it but I had to drill.out the threads on the top mount because the bolts have to come through on the motor side![]()
Almost there 50, looking good. Hanging to see the mounted pic, as in my soon to be published new build I am going to have similar issues![]()
It's all coming together nicely mate...Nice.
Rock n Rolla !
The body will have to be cut to fit. But looks tough!![]()
you got a close up on the wing mount through the shock tower?
wow !!! very large tire on that ! nice job on the wing mount/wing
Jo![]()
Thanks!
Pic of front or back?![]()
Thanks 50, that is what I was chasing. Nice work on the mount![]()
Thanks!
I do wish the wing was a little taller but I want strength more then anything else
I used tony's bolts to mount it. They should be good!
these guys with air guns ruined my hill climb!
i am going up with a shovel monday
luckily they didn't ruin the lower jump![]()
whats ruined in the pic there? cant see or tell what it is. i like that jump with the emaxx nice to get it with the wheels spinning
DEU 8:18 ESV
ok! flm chassis ordered!
whoa just like that.... that is some serious damage you guys did to the emaxx. what was that on? the jump or what? looks like it hurt that time.
DEU 8:18 ESV
that's at the end of the jump!landed and came apart . i had just picked my revo up and noticed the broken summit shaft and my daughter said oh no! i looked up and saw it in two pieces!
thought i was done buying parts for a while. had 61.00 in paypal from a refund and planned on keeping it there!
ooh that sucks you find one broken but 2 now that is just not fun, atleast you got some bashing in right?
how long did that summit axle last for?
I know how that is atleast you had 61.00 in paypal i had that for about 1 week then now its sitting at 16.50 only been there for 3 weeks now needing tires for the merv going with dirt hawgs on desperado wheels found some on ebay for 39.99+8.95 shipping i'll see if i can find cheaper.
DEU 8:18 ESV
i have found 46.44 shipped . so shop around
one thing i noticed on a pic of the halfs is the body? did the body break? sure looks like it did
DEU 8:18 ESV
i had to trim it for the wing![]()
ooh ok thats why it looked like that, nice emaxx and what you have done to it. it will look totally different now with the flm chassis
DEU 8:18 ESV
never wanted so much aluminum but oh well!
