Results 1 to 3 of 3
    Front wheels keep losing drive
    The front wheels wil all of a sudden lose drive and then come back whenever it decides. Driveshaft is ok, added front diff oil. Any thoughts.
    Mt. Washington, KY
    232
    All diff gears ok?
    Feb 2010
    El Sobrante, Ca
    8,113
    Check your wheel hex. Then check the hex pins. Be sure the grub screw on the rear gear for the driveshaft s tight. Those should fix it for you. If not, we will still get you fixed!
