Results 1 to 7 of 7
    Southeast Missouri
    92
    I have to push the trigger forward twice to engage reverse
    I just upgraded my son's Grave Digger to Traxxas TQ 2.4ghz radio system. I have everything setup. I had to reverse the steering servo. The problem is that you have to move the trigger forward twice to get braking/reverse. I'm sure it is a programming issue, but I'm not having any luck figuring it out. I have searched the forums, but I can't seem to find anything. Any help would be appreciated, thanks!
    No Honey, I have had this one for a long time....
    Coeur D'Alene, Idaho
    180
    Have you adjusted throttle trim to try and compensate for it?
    2012 Frankenpede
    2008 Stampede VXL
    Southeast Missouri
    92
    I did have to adjust throttle trim, but it didn't seem to help this particular issue.
    Southeast Missouri
    92
    I just noticed the radio forum. I copied my thread to there since it is probably more appropriate.
    Southeast Missouri
    92
    So this is correct. Once forward is brake, twice is reverse.
    2,450
    Yeah, with the amount of power some of these brushless combos can make, going straight to reverse after going forward could bust up some transmission gears. When you come out of going in reverse, the esc might delay the forward trigger input, also. If you want to do spin outs by turning the wheel and hitting reverse, youll want to hit the brake once. If you want to get a lot of speed and try a 720, you'll need to hit reverse twice
    South of St Louis
    5,986
    Yup that's what its supposed to do. Whomever designed it that way was a smart guy.
