Thread: Slipper clutch
    red deer alberta
    565
    Slipper clutch
    Just got my new bearings installed in My summit so I put the transmission back together and I tightened the slipper clutch up fairly tight and just tried it but it was still loose so I tightened it As tight as I could and it's still slipping any ideas? ?
    Sent from my SGH-T989D using Tapatalk 2
    summit and e-revo sv2 5700, BL p2ede
    Sep 2009
    Victoria B.C Canada
    5,073
    The friction disk could be glazed.
    Fine sand paper and lightly sand the disk /make sure it and or the pads are not contaminated with lube etc
    Same thing with the pads.
    Sent using lipo power
    Mountains cant stop me
    they have tried
    Half moon building out back
    730
    ON top of what jaymann said also try cleaning the disk with alcohol after lightly sanding also might try the alcohol on the pads just to make sure no oil or grease is on them.
    Endeavoring to persevere !
    red deer alberta
    565
    Okay I will try that thanks
