Thread: Servo upgrade
    Feb 2010
    251
    Servo upgrade
    has anyone used the Hitec HS-225MG?
    how do you like it if you do?
    is there another servo you suggest?
    Woodward, OK
    468
    I run that servo, works good, a little touchy, plenty strong. You will have to be careful installing, it fits tight. I used dremel and made a little notch for the wires, otherwise you may damage wires getting it in there. The traxxas horn will not fit, I trimed one of the ones that come with it down and drilled a littler bigger hole for the screw. I have not had any issues with it, like I said I think it is a little stronger, and faster than the stock one. I turned my radio down, because it was a little touchy, and hard to keep straight at high speed. Hope this helps, good luck
    T-maxx 3.3
    Rusty 2.5r
    Summit VXL
    Nitro 4-tec
    Alma, MI
    12,283
    Blue Bird 390 is a drop in if you want to go that route.
    BB 390 Set Up
    All stock hardware is used.
    NONE of the hardware included is needed!
    There are tab braces that do not allow the servo guard to sit flush.
    IT IS OPTIONAL TO REMOVE THEM.
    I have done this both ways without any adverse reactions.
    Here is a picture of the braces:
    (thanks goes to danielhr77 for the picture)
    The tab braces create a small gap between the chassis and the servo guard.
    Here is how it plugs in:
    You will also need to reverse the servo direction.
    These are the steps for LINK and TQi radios:
    Hold MENU for 3 seconds
    Green Blinks
    Press MENU
    2 Green Blinks
    Press SET
    Green Blinks
    Press SET
    Red Blinks
    Press SET
    8 Green Blinks
    Hold MENU
    Setup Complete
    Tazewell Va. Were so small here in taz. that we only have 3 stop lights....and one is broke
    169
    futaba has a metal gear servo that bolts right up also, and you dont have to mess with the settings.
    169
    does anyone know what the voltage output to our servo is???
    Alberta Canada
    895
    I have that servo, It looks to be a real tight fit, takes some dremel work I'm waterproofing it before I run it. I might try the bluebird 390 in my MERV, just going to wait till spring when I order a few batteries.
