Results 1 to 12 of 12
    Bodrum-Muğla-Turkey
    11
    Question TQ 2.4 Ghz Loss of signal problem I cannot find reason
    Last 2 days, my system lost signal 5 times. I checked antenna wire,it looks like not damaged and changed all batteries. I read some threads they said their system connected when they went to near their model. But my system never reconnected. Only I on and off reciever they reconnect. I can't found any reason for it.
    can anyone help me what its reason?
    Alma, MI
    12,282
    What is the voltage of the radio and receiver?
    Bodrum-Muğla-Turkey
    11
    6v. I use alkaline batteries.
    Bodrum-Muğla-Turkey
    11
    Today I try my car at full throttle it lost and regain signal 2 or 3 times in 1 run. after 3 or 4 runs it totaly lost signal. these repeat 2 times. at the first time it does at 25-30 meters. at the second times it does at 5 meters. i rebound it but i can't try it.
    Can anyone say another causes of this.
    Toronto
    2,326
    The batteries are fine in the remote, AND the receiver?
    The antennas are both fine in the transmitter and receiver?
    Have you opened the receiver box at all to make sure the antenna is healthy?
    North Central OH
    1,047
    Might try just running it straight away from you and see if you lose signal at same distance each time, if so it is likely an antenna issue. Does your antenna have the small lead on it that extends from the hard silver part? If not that is likely the problem.
    Bodrum-Muğla-Turkey
    11
    I try but it's not work and it makes fail safe differnt distances(reciever flasing red light). I'm sure batteries are fine. And I checked reciever antenna looks like not damaged. In local rc forum, they said my throttle servo may damaged and it lock the reciever. Is it posible?
    Alma, MI
    12,282
    Are any of your servos warm to the touch?
    Long Beach, California
    6,578
    could it be your remote antenna inside got disconnected?
    Bodrum-Muğla-Turkey
    11
    I don't know I didn't check when it done.
    Alma, MI
    12,282
    When a servo is malfunctioning, they are usually warm to the touch.
    If the servo is cool, it may not be the issue; this is why I asked.
    Bodrum-Muğla-Turkey
    11
    when my mid-term exams will finish, I will check that.
