Results 1 to 7 of 7
Thread: Loose ESC
    Brooklyn Park, MN, USA
    51
    Question Loose ESC
    Hey all,
    With my 4X4 Pede, The bolt that holds the ESC in place no longer sufficiently tightens to really hold it in place well.... And when bashing, jumping, etc, this becomes a problem. Will a new bolt do the trick, or do I need to modifiy the existing bolt (add superglue) to once again have a secure hold? Or get a longer bolt?
    Anyone else have this problem with a loose ESC?
    Perham,mn
    62
    I had the same problem and I just put a longer bolt with a nut on it.
    Salisbury, NC
    633
    When that happened to me, I got a slightly larger diameter and long enough to end flush with the bottom of the chassis screw. It has never loosened again despite some pretty brutal crashes.
    Wales in the UK
    5,213
    I had to do the wider screw thing but then it was all good until my vxl gave up after almost 2 years service...peace
    Saint Louis, MO
    504
    Same here. Went and bought a slightly longer screw. Stays put now.
    Liverpool, New York
    541
    Common issue. Longer screw will do the trick.
    Okanagan Valley B.C.
    728
    Sorry I don't have any pic's but I used a long pan head screw up through the bottom with a nut on top, problem solved.
