Results 1 to 9 of 9
    191
    O.S 21tm on the way
    Well I finally purchased the new engine for my Revo & also an ST Racing (STRC) 3 shoe clutch & 40mm flywheel kit, can't wait till it gets here, although will probably take a few weeks.
    Just need a couple of new CB bearings now but have plenty of time to get them before the engine arrives.
    Will give me time to go over the Revo & stick some threadlock on some of the screws that have worked loose as I haven't done that yet, just been re tightening them.
    Anyone got any advice about the engine & what set up I should go for with diff/trans oils & suspension, I want it to handle as good as it can & jump well to. I have put heavier springs on it, (silver fr & blue rear) but not changed oil from new. Everything is stock atm but will do more upgrades after I have the engine in & running properly.
    I will be using the standard 14/38 gearing that came on the 3.3, the standard wide ratio trans & running 20% nitro with 12% oil.
    Is there anything else I should know, like mods to throttle linkage if needed or mods n parts needed for easy start fitment. Tiger drive will probably be added later on.
    Thanks for any help. I can see this is going to be an on going project,lol.
    Jul 2011
    S. Jersey
    713
    The ez-start will bolt right up. Your linkage will be fine too. I had a OS 18TM in mine. It is a great engine. I was running 16/38 gears in mine and it would pull wheelies on demand. The 21tm will be my next engine. What pipe are you gonna use?
    191
    So I might be better off going with a 15t clutch bell instead of the 14t with the 21tm. Might see if I can find a CB with bearings on ebay somewhere.
    The engine comes with the exhaust manifold so atm I'm just going to use the Traxxas resonator pipe that came with the Revo then when I can I will get a better exhaust, want to stick with the rear exhaust though & was thinking this one might be good if it suits the O.S engine.
    http://www.ebay.com.au/itm/390415321...84.m1438.l2649
    Jul 2011
    S. Jersey
    713
    The ths is a good exhaust. I have the hard coated one on my Jato. You will definitely notice a difference.
    191
    So that exhaust will fit & suit the O.S engine then, I wasn't sure if it only suited the 3.3 exhaust outlet of if it fits all engines around that size.
    This is the clutch & flywheel I have coming
    http://www.ebay.com.au/itm/230867041...84.m1438.l2649
    I have been told the standard Traxxas CB will fit without a problem so if I get a 15t CB with bearing for a 3.3 then it should fit without any issues, I was just looking at this one
    http://www.ebay.com.au/itm/230523606...84.m1438.l2649
    Do you think this will be right, it doesn't say its for Revo but doe's say it suits the 3.3, or do you know of a better option that will suit the clutch & Revo. Thanks
    Jul 2011
    S. Jersey
    713
    That clutch bell won't work in for the jato. The pitch is the 0.8 the Revo is 1.0 pitch.
    http://buy.traxxas.com/images/products/5215.jpg
    191
    Thats weird, I thought the pitch would be the same considering Traxxas make them both, didn't think the would change the gear pitch from 1 rc to another, & considering the use the same engine.
    Maybe its just easier to grab a couple of quality clutch bearings & worry about CB's later on.
    Okanagan Valley B.C.
    727
    Heres a vid of my revo with an os21tm 16/36 clutch and spur traxxas single chamber pipe.
    http://www.youtube.com/watch?v=MsvybWx7ReE&feature=plcp
    191
    I watched that vid the other day, it certaianly goes alright, likes to lift the wheels with that gearing to.
    I see you have a few vids on youtube showing the break in you done so I subscribed & will check them out to.
