Results 1 to 15 of 15
Thread: I need help
    Sep 2012
    Odessa, TX
    72
    I need help
    I went to do some bashing and when i plugged in my batteries and turn the switch on i didnt hear it beep at me like it normally does while it connects with the remote. i turned the esc on and off a few times unplugged the batteries a few times. I open up where the receiver is and everything is plugged in fine. I also tried different batteries that i have. I'm not having any luck. any suggestions?
    Off to the hobby shop I go.
    Australia
    3,259
    Are you saying that the ESC has no power...is not turning on???
    Rock n Rolla !
    kansas
    7,862
    bypass the on/off switch..
    edit it will not void any warrenty...
    Sep 2012
    Odessa, TX
    72
    yea i think so. lol
    Australia
    3,259
    I was going to say exactly as 87GN said...I did it to mine; post #16
    Rock n Rolla !
    Sep 2012
    Odessa, TX
    72
    Quote Originally Posted by craig.mitch316 View Post
    I might try that. How do I have to take the esc apart to get to where the wires are that need to be soddered? Do a lot of people have problems with this switch?
    Australia
    3,259
    I've heard of a few on here, the switch becomes a problem...I've had 2 switches go on me now; I've bypassed them and have never had any issues since. Here is a Link on how to remove the ESC from the case.
    If is stuck to the chassis and you don't want to remove or pull loose from the foam pad...just pull the sticker down far enough off the sides of the ESC cover, do then as per instructions so you can remove the ESC and leave the bottom half of the ESC cover on the chassis...doe that make sense?
    Rock n Rolla !
    kansas
    7,862
    Just cut the wires at the switch, solder or wire nut them together...I did a male female wire connector just in case I need to unplug the two wires. Never have..........tho
    Sep 2012
    Odessa, TX
    72
    K. Yea it makes sense. I had already removed the esc from the chassis but didn't open up the esc housing.
    Jul 2012
    18
    i wouldn't worry about taking the case off and all that, just solder them together outside the casing
    Sep 2012
    Odessa, TX
    72
    K. I just got home and removed the switch and connected the wires together and it worked fine thanks for helping. .
    so cal
    9,244
    i had to do that to my mmp switch. on a hard hit and sometimes a fast speed run the switch would move just enough to shut the car off. nothing like the feeling of hitting the throttle and it doesn't move-thinking motor or esc problems!
    RC Turnbuckle Jr. rjm2519's Avatar
    Feb 2008
    Fl
    3,062
    As long as it doesn't start sizzling, popping, and smoking! I can deal with a button issue, lol!
    Donít handicap children by making life easy
    Sep 2012
    Odessa, TX
    72
    I know right? It had ran fine last time I had used it. But when I went to do some bashing this last time. . .nothing. but all good now.
    Australia
    3,259
    Good to hear its sorted mate .
    Rock n Rolla !
