Results 1 to 11 of 11
    Aug 2012
    North Cack
    115
    traxxas thread lock
    Does anyone know what kind of thread lock Traxxas is using on its parts. It seems to be brushed on. I have some of the blue "thread lok", and it just runs off the threads and doesnt work nearly as well. TIA!!
    hey, you need a real driver for that car?!?
    Long Beach, California
    6,591
    the one your using are fine you just have to give it time to dry.
    | Rally GT8 Powered By CC | BackSl4sh Roadrunner |
    Aug 2006
    LEICS, England
    4,646
    You can also buy Loctite in a stick form which is much easier to use. I was going to put up a pic but it won't work. Google 'blue loctite stick' and it comes up.
    Because it is solid rather than liquid it means you can apply it very accurately and it doesn't run everywhere. My guess this is what manufacturers use.
    If at first you don't succeed, redefine success.
    Marshal carraig042's Avatar
    East Tennessee
    6,690
    I believe loc-tite says it take 24 hours to cure. I would at least let it sit overnight though.
    Also to consider. Make sure the threads are clean and free from oils/etc. I have noticed that this makes a big difference.
    -Brett
    4wd Sportmaxx 3.3
    6,591
    Quote Originally Posted by carraig042 View Post
    -Brett
    i agree....i always clean the threads with hobby knife.
    Oct 2012
    Wyoming
    175
    They also make the gel form, works great.
    Who needs brakes!!!!
    Australia
    3,259
    I use a wire brush
    Rock n Rolla !
    Oct 2010
    NJ
    777
    I just tried out Vibra-Tite VC-3 Threadmate. Its similar to the Traxxas thread-locker. You apply it to the threads and let it dry. It forms into something like a plastic and its similar to using a nylon lock-nut. When its dry, just bolt up. Its supposed to last for 5 uses. So far I've removed my wheel nuts and put them back on 3 times with the same application and its holding up to 5s.
    If you use this, don't put it on the first few threads like I did. I couldn't get the nut started till I peeled some off. doh!
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=150922410854
    Aug 2012
    North Cack
    115
    Yeah, I always make sure my threads are clean. It is just very runny. It works, but the thread lock that traxxas uses seems to work better. Plus I like how you can apply it to just a portion of the threads. Put it all the way around if you never want a screw out, or just a dab to keep it tight. Maybe I'll try the stick. The traxxas thread lock almost seems if it was applied with a brush tho.
    High Point, NC
    13
    Has anybody figured out what Traxxas uses on the factory parts?
    We know it is blue and that it doesn't run. I have tried the Loctite blue stick and that is not the same stuff. While VC-3 may be good stuff, it is red. So, we know VC-3 is not the same stuff Traxxas uses.
    Has anybody called and asked Traxxas?
    The stuff they use is perfect.
    Minnesota
    1,306
    Quote Originally Posted by bcadman View Post
    Theirs is applied by a machine....of coruse its perfect.
    ERBE
    Savage Flux XL
    Trail finder 2
