    127
    looking for a cheep paddle tires salution
    Hi all.
    I would like to buy 2 paddle tires for my Slash 2WD, I think getting the tires only will make it cheaper.
    as my original tires are almost slicks, I thought I could assemble the paddle tires on the original rim after ill take the used tires off.
    what do you think of this: http://www.ebay.com/itm/Panther-1-10...item2a1fef3d86
    will they fit the 1/10 2WD original rims ?
    Thanks
    Jul 2012
    246
    no you need to get short course tires those ar buggy tires
    check out proline sling shots these will fit on your stock wheels
    http://prolineracing.com/tires/sling...2.2/3.0-tires/
    sl2sh, p4de trail truck
    Temecula, CA
    383
    Quote Originally Posted by RCTRAIN View Post
    I agree, this is the way to go. You can remove the old tires by putting them on a cookie sheet lined with foil into a 350 degree oven for 15 minutes. You may stink up the house, so keep that in mind.
    I Wanna Go Fast!
    Jul 2012
    246
    or you can soak them in acetone overnight to remove your tires but be warned it may runin your crome
    or boil them in water
    or if their used alot (like bald) you can just rip them off and then pick off the little bits of rubber
    heres a video
