Results 1 to 10 of 10
    May 2010
    263
    I turn left servo go right
    Ok so i got a new single servo its a hitec 200oz i know thats not a bunch but it works for me. so when i turn the wheel on the transmitter to go right the servo turns left. How do i fix this?
    Slash rocks!!!
    Jul 2010
    London,KY
    316
    Make sure its not plugged in backwards in the rx. If its correct, you can reverse the steering on the tx.
    Alma, MI
    12,283
    It wouldn't work at all if it where plugged in backwards in the Rx.
    To reverse the servo direction.
    These are the steps for LINK and TQi radios:
    Hold MENU for 3 seconds
    Green Blinks
    Press MENU
    2 Green Blinks
    Press SET
    Green Blinks
    Press SET
    Red Blinks
    Press SET
    8 Green Blinks
    Hold MENU
    Setup Complete
    15,689
    All Hitec servos need to be reversed. FWIW.
    Alt-248 on the number pad =
    Jul 2010
    London,KY
    316
    Maybe so, but I could have swore I've put the servo in backwards before and it reversed the direction. I think it was either a Hitec or Spektrum servo.Shoot, it may have been a Spektrum rx as well. Hah, I'll just blame it on age and say I imagined it.
    central nj
    51
    can you just move it to the other side of the truck
    Victoria B.C Canada
    5,143
    Quote Originally Posted by onetuffmj View Post
    No it needs the channel reversed
    Sent using lipo power
    Mountains cant stop me
    they have tried
    the middle of nowhere
    419
    No, the servos actually run on the same channel and rotate the same direction.
    They push/pull because they are mirrored to each other if that makes sense.
    15,689
    Quote Originally Posted by DocSnake View Post
    Ground, power, & signal are the three wires. The servo should not work at all if the plug is backwards.
    May 2010
    263
    Green Blinks
    Press MENU
    2 Green Blinks
    Press SET
    Green Blinks
    Press SET
    Red Blinks
    Press SET
    8 Green Blinks
    Hold MENU
    Setup Complete
    Thanks for reply already found a YouTube vid on how to thanks all!
    Slash rocks!!!
