Results 1 to 13 of 13
Thread: mod 1 gears
    Wyoming
    175
    mod 1 gears
    So Ive been searching these posts and cant seem to come up with a solid number, more than likely gonna trail and error but what size are any of you using with mod 1 gears?
    I decided to change out to these because they are a lot more abundant at my LHS than the 32 pitch.
    I'm starting out with a 17 pinion and 40 spur.
    Who needs brakes!!!!
    Aug 2006
    LEICS, England
    4,646
    I can't remember which pinion I've got, but I've definately got a 40t spur.
    Just a word of warning, because of the size of the spur it is difficult to use an HPP motor brace. With my set up you have to force one bolt past another. My ERBE also seems to run a little warm on 6s but it's a long time since I've tested the temps. On the plus side, I stripped several 32p spurs, but not a single mod1.
    If at first you don't succeed, redefine success.
    kansas
    7,820
    is this a converted nitro??
    how many cells..
    Wyoming
    175
    Quote Originally Posted by eemmaaxxxx View Post
    Pretty much the reason I decided to go with mod1, seams a little more stout.
    Think ill just keep an eye on my temps and go from their.
    I have the stock motor mount on it now, just have to cross that bridge when I get my motor. Some modification is not a problem
    Wyoming
    175
    how many cells..
    no, it was a roller I got. Believe it is the brushless. Came with 2 68t 32 pitch spurs. Not sure what he was trying to accomplish with that tall of gear, but it had a broken chassis and rear bulk.... 6 s
    kansas
    7,820
    I could be wrong but I think it will not mesh...the gears.. 17/40
    Aug 2006
    LEICS, England
    4,646
    That is the issue with the HPP brace. The motor has to be laid right over to the centre of the truck.
    Wyoming
    175
    Ya, i already got the gears spur and pinon. both mod 1. took out the 32 pitch spur
    kansas
    7,820
    wee
    2/3s
    17/40 = 69.82 mph
    Spur/Pinion Reduction Ratio 2.35 : 1
    Wyoming
    175
    wee
    2/3s
    17/40 = 69.82 mph
    LOL... im shooting for 100 mph, jk!
    I did check the mesh and still have plenty of room on my motor mount for a smaller pinon.
    87 GN, would you happen to have a chart like the one for 32 pitch for the mod1 gears?
    kansas
    7,820
    sorry.... no chart I use BrianG site...... kind of fun to use once you know how to change up the options...
    Diff ratio
    4s = 40 mph
    5s = 50 mph
    6s = 60 mph
    change the cell count, spur & pinion count, & tire size.
    BrianG speed chart:
    http://www.scriptasylum.com/rc_speed/top_speed.html
    Copy / paste: Import this:
    Differential Ratio: 2.8461538461538463
    Transmission Ratio: 1.8333333333333333
    Other Ratio: 1
    Spur Tooth Count: 54
    Pinion Tooth Count: 21
    Total Voltage: 22.20
    Motor KV: 2200
    Tire Diameter (inches): 5.9
    Tire Ballooning (inches): 0
    Motor Current Draw: 0
    Motor Coil Resistance: 0.006
    Spur/Pinion Ratio: 3 : 1
    Total Ratio: 15.65385 : 1
    Tire Circumference (inches): 18.54 inches (470.8 mm)
    Rollout: 1.18:1
    Total Motor Speed: 48840 RPM
    Vehicle Speed: 54.76 mph (87.97 km/h)
    Effective KV Value: 2200
    KT constant: 0.61 oz-in/A
    Wyoming
    175
    Diff ratio
    4s = 40 mph
    5s = 50 mph
    6s = 60 mph
    BrianG speed chart:
    Other Ratio: 1
    Motor KV: 2200
    Rollout: 1.18:1
    Ahh... Gotcha. Thanks i will do some playing around with that
    18
    i was running a 25t pinion and a 34t spur it needed a little less acceleration but I dont think you can fit any bigger of a pinion with the current motor mount
