Page 3 of 3 FirstFirst 123
Results 81 to 110 of 110
Thread: my revo
  1. #81
    392
    Well gears are a success I did the same things with it today that I did when I stripped my gears and nothing runs like a dream wide ratio is still good for the big block still wheelie on demand and more top speed just got to mess with my shift point now shifting too early by that's simple overall good day my buddy stripped a spur in his maxx and my other buddy's revo is good he hates his 3.3 but a lot of people do I didnt mind mine too much you just gotta learn to tune
    drive it like you stole it
  2. #82
    392
    Ok a question I'm thinking about goin to a side exhaust what do I need to mount it and how do they hold up to bashing do they stay still or do they come loose a lot and what's a good pipe I was thinking the big block buku pipe
    http://www.bukupower.com/BigBlock.aspx
    Does anyone know
  3. #83
    392
    Anybody wanna help with this
  4. #84
    Aug 2012
    191
    I found the 3.3 to be a good performing engine, wasn't to bad to tune but it just didn't last that long, I got the clutch/flywheel today so will get it all back together & see how it goes. There's been a few people who have used a side exhaust so hopefully someone can help with some info. What exhaust do you have atm, the THS rear exhaust is meant to be pretty good.
    REVO 21tm grunt & JQ Products "The Car" GO NITRO
  5. #85
    392
    I have an rb 523 exhaust it seems pretty good but I don't have nothing to compare it to other than the original resonator and I don't wanna put that on
  6. #86
    Aug 2012
    191
    The original resonator pipe is supposedly meant to be alright but pipes like the THS make a big difference over the standard pipe when used instead from what I have read, thats why I was getting one, the THS was one of the better pipes around & their not that expensive either which is good.
  7. #87
    Aug 2012
    191
    Also, you could try drilling the stinger out a little bit just to enlarge the exit hole, only a very small amount though. From what I have read, it is a good way to gain a little extra power. It should only be done a very small amount though or it could cause a loss of pressure & power. I read about it in a thread somewhere, not sure if it was here or another forum though.
  8. #88
    392
    robinson racing gears
    ring stuck on the drive shaft
    melted carrier
  9. #89
    392
    got some runnin in today took some pics
    also noticed today that my hexes are starting to wobble on the shaft ive never had that happen before how can i eliminate that
  10. #90
    2,004
    Some guys wrap the threads with Teflon to take out the play. There are low end hub adapters and low budget mods to fix it as well. Check around the E-Maxx forums for mods
  11. #91
    392
    Alright thanks red how do you like your old baby man is she sweet the 523 rr gears mashers pull start foc and bout to have the cvds in as well we clocked it at 57 with the wide gears
  12. #92
    Aug 2012
    191
    For the lose hubs I put some electrical tape around mine, its a bit thicker the teflon tape & lasts a while to, 2 layers was all that was needed & I had to twist the hubs on to get them in position. After 4 or 5 tanks there is still no movement in them.
    I did put a couple of layers of teflon around the little plastic ball cup screw in things that go into the axle carriers & hold the pivot balls though, it should stop them from working their way lose a little hopefully.
    Looks like you got your revo going well again, I just got my O.S installed & about to go start the run in process today.
  13. #93
    392
    yea i have to get an exhaust gasket cause mine ripped and i have to get the gas tank o ring but i might have one in my shop hopefully cause we have quite a few o ring kits
  14. #94
    392
    Well got my new hot racing aluminum diff cup filled with 50k oil in after I stripped the spool out of it haha 523 has a lot of power and it's showing with broke parts yesterday stripped the front drive shaft out gotta start taking more pictures before I replace and throw away next imma need cvds what kind should I get I'm looking at the mip splined one anybody usnig these o ya also ordered new motor mount ring and pinion for when it finally goes what else do y'all think I need
  15. #95
    Oct 2012
    90
    rustlerrevo....what engine mount did u have to use to mount that 523? i really like those engines, just dont know what i need to stuff it in my revo.
    revo 3.3 tmaxx 3.3 ofna hyper 7
  16. #96
    392
    outlaw i bought the engine at a hobby shop it came with the mount already attached and fits right into the the stock outer mount pieces
    here is one for sale mount and pipe just like i have this pipe it comes with is really loud but sounds good
    http://www.activepowersports.com/rb-...e01901523000r/
  17. #97
    392
    but if your gonna do it look into upgrades it tears parts up fast if you really get down on it often
  18. #98
    392
    parts ordered
  19. #99
    392
    Well broke the pin in the tranny again the one with the c clip thing holding it in place is there a upgrade for this aide this is like the 5 th one and it's getting old fast
  20. #100
    392
    Well got the hot racing 3 shoe clutch in yesterday and installled along with my cvds hopefully I don't break them anymOre I'll post pictures later
  21. #101
    392
    well got back from deployment fixed the revo up got new exhaust I modded it to have a stack heck ya fixed my stripped wheel and prolly gonna go to the beach with it
  22. #102
    Biggest Little City In The World
    723
    First off thank you for your service its good to have you home Second i read your whole thread nice build.
    " You just got passed by a Traxxas"
  23. #103
    392
    Well thank you and yea it's been a lot of time and a lot of money getting this beast goin here's the picks
    IMG]http://i1110.photobucket.com/albums/h446/ct132/IMAG0054_zps46606c56.jpg[/IMG]
  24. #104
    392
  25. #105
    milwaukee wisconsin
    169
    that exhaust is sweet man im loving it
  26. #106
    723
    do you have problems with spent oil pooling up in the elbow of the exhaust where it turns up? I have thought of this idea before of running like a stack type pipe. Just didnt know if pooling would be a issue.
  27. #107
    392
    No no polling of anything it just won't stay
  28. #108
    392
    Here is thenend I've done about all I can do the onlynthing left is badlands and tekno tank kit
  29. #109
    392
  30. #110
    392
    well I have twisted traxxas steel drive shafts twice what better do any of Yall run summit shafts
