Results 1 to 33 of 33
Thread: 1/8 scale tires
    May 2009
    Edmonton, Alberta
    3,604
    1/8 scale tires
    Anyone been able to see if there is clearance to run a 1/8 buggy wheel on these guys?
    Also is there a 17mm conversion that doesn't increase width?
    I had the AKA 17mm conversion on mine and im sure that pushed the wheels out a bit.
    Main reason for asking is i have a new set of Dynamite RoadRunners which are a full 1/8th rim but very thin rubber section. Would love to try them on this when i get it.
    South of St Louis
    5,986
    Quote Originally Posted by Cameron View Post
    I'm picking up my Roadrunners Friday when I'm off work along with a set of TRX 17mm adapters for my Rally. I'll post some pics when I get it together.
    May 2009
    Edmonton, Alberta
    3,604
    traxxas made a set of 17mm hubs that work on the slash axles? I did not know that.
    Aug 2006
    LEICS, England
    4,646
    Yes Splined 17mm hub adapters. There is a set for the 2wd Slash, different offset front to rear, and a set for 4x4 Slash/Pede etc which is same offset all round.
    6856X - 4x4
    5853X - 2wd.
    Hope that helps.
    If at first you don't succeed, redefine success.
    7,171
    Yes they do. I have a set of 17mm adapters but have yet to use them. Just make sure you get the right kit like emax posted above and not for 2WD as they have diff offset.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    South of St Louis
    5,986
    I think the Rally will look great in a set of buggy tires. I like the 1/8 profile.
    Jul 2009
    Ontario, Canada
    11,145
    I did a bunch of research on this in my "aftermarket observations" thread. Most buggy tires (with realistic tread) are about 108-112mm in diameter
    Most 1/8 GT car tires are between 96 and 102mm in diameter.
    The stock rally tires are 102mm in diameter. So, if you get the right ones, the buggy tires/wheels should fit. Also, BSA makes 1/8 onroad foams that are nearly the exact diameter of the stock tires.
    The buggy tire/wheel setup im looking at right now is the Duratrax Derringer. Not too aggressive, but not too mild either and the diameter is very close to stock. Found some nice spoked ofna wheels for them so it should still look pretty good.
    Also, im not sure if the traxxas adapters address this or not. But you would need adapters that add a small amount of width. Buggy wheels are a very high offset so they dont stick out very far. Certainly not as far as the stock rally wheels do. If you just used a +0 17mm adatper I think youd find the track width would end up narrower. I have a set of integy +6 adapters... that may be too much. I think +3 is ideal.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    7,171
    Thumbs up
    Those look clean Pave. I bet they hook up nicely. Wonder how good the wear is on them. The nobbies are really short.
    FEATURES
    <>Random shaped tread ideal for loose (dry and loamy), mud (wet), hard packed (wet), pavement and grass track surfaces
    <>Molded from worldwide race-winning long lasting C2 compound
    <>Color-coded sidewall markings make it easy to identify each tread pattern at a glance
    <>Resealable packaging
    SPECS
    <>Inner Diameter: 3.1" (79mm)
    <>Outer Diameter: 4.25" (108mm)
    <>Width: 1.6" (41.5mm)
    I found some good look'n Ofna V-Spoke wheels. Many they come in all flavors. It would be a hard decision if I'd go with Orange, Black, or Black Chrome. LOL The OD of these is a little bit more than the ID of those treads. Is that ok for the fitment of the 2??
    V-Spoke
    SPECS: Width: 1.65 (42mm) Diameter: 3.3 (80.5mm) Hex Size: 17mm
    Dual Spoke
    SPECS: Outer Diameter: 3-1/2 (86mm) Inner Diameter: 3-1/8 (77mm) Width: 1-5/8 (40mm) Hex Hub: 3/4 (17mm) Axle Hole: 1/2 (10mm)
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Aug 2006
    LEICS, England
    4,646
    Double post.
    Aug 2006
    LEICS, England
    4,646
    Those tyres look really nice. There's a company in the UK that do cheap Buggy premounts that I like the look of. Something like this.
    How long will it be before someone uses mini pins
    Port Alice, BC, Canada
    1,290
    Just ordered these.
    With these.
    Also got a set of street fighters on order for my PL Beadlocs 2.2/3.0. And also ordered up a set of PL 1/8 Knuckles for the set of extra V2 Split Six wheels I got laying around.
    I have the Hot Racing 17mm adapter for the Slash 4x4. Not to sure how much they extend. Been looking can't really find the info. Pics when I get everything for sure
    R4lly GT8 | Backsl4sh | Sl4sh MT | Sl4sh | P4de
    May 2009
    Edmonton, Alberta
    3,604
    have fun gluing those up... i have had 2 Ofna GTP2e and a DM1. You would think i have gotten the hang of those darn tires by now... they get tossed or sold when i see them now.
    1,290
    They are a pain i'm guessing? lol. Oh well, will see how it goes
    May 2009
    Edmonton, Alberta
    3,604
    There is a video on youtube from Jang that helps, but yes they are a nightmare. And if your tires are the belted ones it is even worse. Why they used that 2piece foam is beyond me. a single closed cell foam is so much easier to install and work with.
    They use them on almost every other tire.
    Nov 2011
    North Central OH
    1,047
    Quote Originally Posted by Stephan81 View Post
    Just ordered these.
    With these.
    And just what are 'those' tires??
    Nov 2011
    North Central OH
    1,047
    These seem like a nice on/off possibility too:
    JConcepts.....
    I really like the Traxxas stock tire and hope it works out well but a dedicated street/drift combo and a grip tire set will be needed too.
    Jul 2009
    Ontario, Canada
    11,145
    Those are Ofna belted radials for a 1/8 GT car. Not to undermine the OP but you can buy a full set of Sweep Racing Belted radials, pre glued on their wheels for the same price as just the ofna tires. They are way over priced. I preferred the sweeps performance as well.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    Nov 2011
    North Central OH
    1,047
    Thanks Pave I am not familiar with street tire offerings yet, more to learn as usual......
    If anyone cares to suggest tire brand offerings to consider that would be great!
    Aug 2006
    LEICS, England
    4,646
    I'm suprised that Traxxas say the tread is licensed on the stock tyres. If you look at the shape of the individual lugs then yes it is a very similar pattern to that used in the WRC. The depth of the tread, spacing between the tread blocks and the depth of the sidewall is no where near accurate.
    I think a 1/8 size tyre but with an accurate tread would be awesome.
    recalculating...
    581
    also available for 1/8 buggy tires is proline badlands and road rage....
    I like turtles.
    Jul 2009
    Ontario, Canada
    11,145
    I looked at the badlands. Because of the aggressive block tread, they end up being really tall compared to the stock tires. Im sure theyll fit, but they may look weird/not scale and will likely cause body rub.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    Jan 2007
    Gilbert, AZ
    1,249
    May 2009
    Edmonton, Alberta
    3,604
    I just measured the Dynamite set i have and they are only 95mm overall.
    for size comparisons.
    Dynamite RoadRunners, Sweep 1/8 Belted GT, JC DoubleCross standard 1/8 Buggy Combo
    I like that look, but i think the 1/8 buggy sets would most certainly rub a ton.
    Colorado Springs, CO.
    2,009
    ^^ HOT!! not very fast but HOT!
    Long Beach, California
    6,599
    i just order this set for my onroad build..is this any good? http://www.ebay.com/itm/310489411409...84.m1438.l2648
    | Rally GT8 Powered By CC | BackSl4sh Roadrunner |
    May 2009
    Edmonton, Alberta
    3,604
    i havent had the stomach to order from him yet, his stuff is almost too cheap. Makes me wonder.
    6,599
    man, i hope its not to big to where i have to cut the wheel well even bigger, lol.
    Aug 2007
    NorCal
    112
    I just put on SC8e wheels and tires. I really liked these tires on my SC8e. Will try them out tomorrow. I trimmed the wheel wells a tad to.
    Rally, Slash 4X4, Summit 1/16
    Jul 2009
    Ontario, Canada
    11,145
    Ran my Duratrax Derringers today with the +6 offset 17mm adapters and with the stock body moved up one hole the front didnt rub at all. I got a little but of rub on the front edge of the rear wheel opening and im sure it would only take a few mm of trimming to fix it. A tire thats slightly smaller would have no trouble clearing at all. Im not happy with the tires on pavement but they seem to hook up quite good in the dirt. However, not as good as the stock tires, so I think im going to switch back.
    Im still going to buy a set of sweep belted radials though. I think they'll be great for some speed runs.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    4
    can you pm me the link you found them on? havent been able to locate them...thanks
    South of St Louis
    5,986
    How are you calculating the offset? Do you measure it yourself or does the manufacturer provide the number?
    Jul 2009
    Ontario, Canada
    11,145
    MFG lists them as +6... I've never measured them myself.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
  33. #33
    Aug 2007
    NorCal
    112
    I have HR 17mm adapters and they do not list there offset, but there is offset. Here is the stock hex held next to them. But, thankfully, they seem to be the perfect width. I did have to trim the body. The rear wheel well about 1/2 an inch towards the rear bumper, as on decent size jumps, the body would get caught up in rear the Tire. I also raised the body one hole. Not sure if that helped yet. I also trimmed the front wells, but not much. I also noticed the extra width has helped out quite a bit on not flipping with Street fighters. Handles great and drifts pretty good if your aggressive. Overall, I like the 1/8 tires and the extra clearance you get.
