Thread: Help needed!
    231
    Help needed!
    I installed new tires and I noticed that my left tire has like toe in? Why? How can I fix it?
    26
    when mine got that way it was because of a bent driveshaft. does your truck bounce or wobble at mid speed on road?
    NJ
    555
    Its a easy fix just turn your turn buckles and adjust your tow in or out
    231
    Quote Originally Posted by Killaonduty View Post
    Hope ir isn't cause I got CVD's
    231
    Quote Originally Posted by slayer17 View Post
    Turn buckles in rear adjust the toe? I think rear are for camber only
    NJ
    555
    Depends on if hes talking about the front or the back. The back if hes running rpms arms they have alot more toe in then the stock a arms. If he is talking about the rear then the only way he can fix that is put the stock arms back on or change the anti squat block. Its quite possible he has somthing bent in the rear if thats what he is talking about
    Quote Originally Posted by subyhau View Post
    Maryland
    107
    I think he is talking about his toe in. The toe is adjusted by the bar that attaches underneath the transmission. You can replace it with varying degrees of toe in with different toe bars. The tires toe in like that to compensate for the flex of the A-arms when moving especially at the speeds that the Jato travels.
    231
    Well i'm talking about my left rear tire.
    Maryland
    107
    right one looks toed in the same amount, its normal
