+ Reply to Thread
Thread: Engine bearings
    392
    Engine bearings
    Alright I need info on how to change my bearings like a broke down cant mess it up explanation my bearings will be here Friday what do need to take apart
    drive it like you stole it
    In a burning building
    8,613
    Take a socket that will just fit through the rear bearing and hold it on the front and tap the front out.
    As for the rear (will work with the front too), heat the block up in an oven at around 250° for about 10 minutes and it'll fall right out when you tap the rear of the block on a piece of wood.
    392
    Do I need to take the head off or anything do they get pressed back in or something
    8,613
    You won't get the piston and sleeve out without the head off. Take everything off do as I said and then the new ones will press in.
    392
    So I pull the piston sleeve and all out sorry for all the questions never done it
    Grafenwoehr Germany
    1,308
    I have a video on YouTube I made search "how to remove nitro crank bearings" the video should be the first one by zachary. hope this helps
    8,613
