Results 1 to 8 of 8
    Florida
    32
    Is this mod possible??
    i was wondering out of curiousness if its possible to mod the 2.4 receiver with the 2.4 antenna.
    Something like this
    Traxxas Antenna: 2.4 GHZ TQ Transmitter TRA2237
    if so that'll be cool.
    12,291
    I think it may be... but you would have to be able to solder it to some very small areas on a circuit board.
    Florida
    32
    i thought that i would but if you open the rx it looks like they made it to be diy fixed. im pretty sure you know what the inside of a 2.4Ghz looks like and how the wire is. idk ill try it and let you guys know. still if someone has done it i hope they see this post lol
    12,291
    Most RC'rs are not comfortable with soldering something that small.
    Colorado Springs, CO.
    2,042
    I just did this the other night...it works but its only got about 60-75 feet of reliable range......
    Florida
    32
    Thats about the distance im getting now. =/
    Toronto
    2,331
    Interesting about the range. Try running it without an antenna installed, and see if there is any difference. I'm worried that perhaps the antenna isn't soldered on correctly.
    I have some IPX connectors that I've ordered, and I was planning on soldering them to the rx board, and then connecting some 2.35-2.45ghz antennas to them. Technically it should work just fine, that's why I'm concerned you may have a faulty solder to the rx board.
    Again, try running it without any antenna, and see if the range decreases - if it doesn't it's clear that the antenna wasn't soldered correctly, however if it DOES go shorter (as in 15-20 feet) than there's something more to this story.
    Good luck!=)
    Florida
    32
    http://traxxas.com/forums/showthread....4ghz-receiver.
    i did this too it, if you scroll down you will see the pictures i posted of my fix. i didnt do this mod yet im waiting to get another rx JUST IN CASE
