Results 1 to 8 of 8
    in a revo
    28
    is after run oil required?
    Hey i as you probably know I recently purchased a revo but it came with a manual and it says you could substitute wd-40 for after run oil I whant to know if its safe.
    any help is appreciated
    revos crush any kind of r/c monster trucks
    Kauttua city, Finland
    196
    You can use WD-40 as after run oil, use it when you are going to store your Revo for more than one or two nights. (As you would do when using normal after run oil)
    |Traxxas|Revo|3.3|#5309|FIN|
    NB Canada
    22
    I used to use after run oil years ago but nowadays I just use wd40 in all my engines. Works great! WD-40 should be a must have item on any RCer's workbench, it's got so many uses in this hobby.
    191
    For the Traxxas engine WD-40 is fine but I would be careful in some other engines, Wd-40 can cause damage to the silicon ramp that is used in the crank of some of them. I would check with engine manufacturer first, some would be fine but some engines may be damaged. The 3.3 is fine though.
    2,188
    wd-40 works as good if not better. Thats all I ever used. If you're only storing it for a day or so then you don't need it.
    Sting like a butterfly and punch like a flea, jack
    in a revo
    28
    okay so Ive got the traxxas trx2.5r so it would be fine?
    revos crush any kind of r/c monster trucks :/:
    196
    TRX3.3 = TRX2.5R with bigger piston and sleeve, literally.
    Simi Valley, CA
    499
    You can use marvel mystery oil also if you have that.
