    Sep 2012
    somewere in ohio bashing a traxxas
    154
    is after run oil required?
    Hey i as you probably know I recently purchased a revo but it came with a manual and it says you could substitute wd-40 for after run oil I whant to know if its safe.
    any help is appreciated
    revos crush any kind of r/c monster trucks
    Kauttua city, Finland
    197
    You can use WD-40 as after run oil, use it when you are going to store your Revo for more than one or two nights. (As you would do when using normal after run oil)
    |Traxxas|Revo|3.3|#5309|FIN|
    Aug 2012
    NB Canada
    22
    I used to use after run oil years ago but nowadays I just use wd40 in all my engines. Works great! WD-40 should be a must have item on any RCer's workbench, it's got so many uses in this hobby.
    Aug 2012
    191
    For the Traxxas engine WD-40 is fine but I would be careful in some other engines, Wd-40 can cause damage to the silicon ramp that is used in the crank of some of them. I would check with engine manufacturer first, some would be fine but some engines may be damaged. The 3.3 is fine though.
    REVO 21tm grunt & JQ Products "The Car" GO NITRO
    2,215
    wd-40 works as good if not better. Thats all I ever used. If you're only storing it for a day or so then you don't need it.
    "I like rc cars"....."WHAT? YOU'RE KIDDING!"
    Sep 2012
    154
    okay so Ive got the traxxas trx2.5r so it would be fine?
    revos crush any kind of r/c monster trucks :/:
    197
    TRX3.3 = TRX2.5R with bigger piston and sleeve, literally.
    Simi Valley, CA
    499
    You can use marvel mystery oil also if you have that.
