Results 1 to 3 of 3
    Lafayette,LA.
    701
    Castle bec question
    When using the castle bec would i still have to use my glitch cap? Thanks
    Apr 2009
    Michigan
    2,297
    No. A capacitor just stores energy for when the servo draws to much causing the receiver to loose power thus causing a brown out. By adding a capacitor you have a little buffer zone to keep the receiver powered. With a BEC everything gets full power as long as the power supply is large enough to handle the load making the capacitor pointless. Its still possible to cause a brown out with a BEC but you have bigger issues if the battery powering it gets below 4.8 volts.
    Oderint Dum Metuant
    Lafayette,LA.
    701
    Quote Originally Posted by reapergn View Post
    no. A capacitor just stores energy for when the servo draws to much causing the receiver to loose power thus causing a brown out. By adding a capacitor you have a little buffer zone to keep the receiver powered. With a bec everything gets full power as long as the power supply is large enough to handle the load making the capacitor pointless. Its still possible to cause a brown out with a bec but you have bigger issues if the battery powering it gets below 4.8 volts.
    thanks for the info
