Results 1 to 11 of 11
    76
    Hot boddies D8 set up questions
    I am tunnin up my slash 4x4 and had a few questions about the D8s.
    1. What is the desired length of the front and rear shocks and is the length measure from eye to eye or end to end?
    2. What is the best position on upper and lower mount? I have rpm arms and towers?
    3. Best spring and weight oil.
    FYI. Setting up for bashing. I run a map 2650 with 3 to 4s, Robinson racing slipper, mip cvds, 17 mm hex and 1/8 wheels and most of the other little up grades. Thanks in advance Doug.
    Atlanta
    839
    1. 95-97mm Front, 108mm Rear
    2. Top - Middle whole F&R
    Bottom - 1st or 2nd closest to the wheel F&R
    3. Anywhere from 20-35wt shock oil, Since you run a MMM, I would go with white springs and 30wt.
    76
    Quote Originally Posted by CyconXc View Post
    Thanks mucho. I reac the other link but couldn't get the length nailed down.
    Cyconcx is that end to end or eye to eye
    Central NJ
    1,245
    I got a set in yesterday and did the mods and I just did a test run with them and liking the SC10 big bore shocks better.
    Ill try again once I get the TRCE adjustable shock towers.
    May be because Im running an LCG chassis?
    Ill just wait until I get the tower and experiment with springs, oil and height. It may just because Im spoiled on the SC10s and have them dialed in already.
    Atlanta
    839
    It's eye to eye.
    76
    Thanks mucho. Ps u have good u tube videos.
    Atlanta
    839
    Thanks Learo, just uploaded a setup video last night. It goes into more detail about the shocks.
    Florida
    360
    Quote Originally Posted by JustinThyme View Post
    I drove an SSC chasis with sc10 shock last night..it felt ligher and was very quick around corners..You really can't go wrong with either set of shocks
    D8 shocks can take awhile to get the tuned in with your set-up..You might wanna try different spring rates or shock oil..You'll love them when get them dialed in.
    Great video!! How much play do you have around the shock cap eyelet where the shocks are mounted shock tower??
    Superman don't need no seatbelt-Ali
    2x SSC SL4x4
    Atlanta
    839
    Quote Originally Posted by DriveItLikeYaStoleIT View Post
    Thanks! As for the mounting, I have no play at all.
    I use these spacers/adapters:
    http://www.amainhobbies.com/product_...hock-Spacers-6
    Sep 2010
    the giant boot. Anybody?
    2,727
    That's a good option. I bought the HotBodies shock mount's for my D8's and it was like 20 buck's. Love my D8's though.
    Bedford TX
    155
    I was hoping you would make video showing how you mounted your d8s. Those are my next upgrade. Thanks bro.
    Backslash 4x4
    FLM Rustler
