Page 5 of 5 FirstFirst ... 345
Results 161 to 182 of 182
  1. #161
    so cal
    9,245
    That is a mamba max pro with the fan removed. Runs so cool you don't need it
  2. #162
    Feb 2013
    6
    that will run with stock velineon 380?
  3. #163
    so cal
    9,245
    Perfectly with the stock motor!
    When it comes to motors and esc's only an esc that is not strong enough will hurt your motor. A motor will only draw what it needs
  4. #164
    so cal
    9,245
    I have ran a stock motor on 4s batteries and quickly got up to 64mph with plenty left to go!
  5. #165
    Feb 2013
    6
    Thanks for the info BTW when i tried to fix my maxx's motor i noticed that pinion is different in 540 motor, isthere a different pinion i can buy for it to fit the mini revo?
  6. #166
    so cal
    9,245
    The mini is 3.2mm and yours could be 5mm. Can't tell without measuring it but they do have a sleeve for 5mm to 3.2 to fit the mini
  7. #167
    so cal
    9,245
    My body was kind is beat so I.picked up a another one to paint. Looks like my erbe body but I tried candy blue on the sides and true blue pearl on top
  8. #168
    so cal
    9,245
    Picked up some strong velcro!
  9. #169
    so cal
    9,245
    I ordered some gh carriers to replace my rpm carriers on my other merv. Has stock axles and tightened the nut up and the tire wouldn't turn. Tried some new bearings and axles then shims. Nothing helped so i pulled my older gh carriers out of my merv to compare. Don't know if they are old stock but the tapered machining is smaller on the new set allowing the axle to drag on it.
    contacted omni models and the gave me a quick refund and don't even want the items back! Old set is on the left
  10. #170
    so cal
    9,245
    I.opened up the taper to match the older set and works like a charm
    I would like to know if this was a first edition. Didn't have the gh stickers either
  11. #171
    Portugal
    293
    can you post the link where you bought the 37pinion? Had to make any mods to the tranny?
    or at least the brand and model of that pinion... 3.2mm ? Is possible to go more up tooth pinion? or less spur then 45?
    Using that pinion on the neu motor, right?
  12. #172
    so cal
    9,245
    this will work http://www.ebay.com/itm/Robinson-Rac...item2a29d0d813 with a small block about the biggest that fits.depending on your motor mount might need to dremal it a little
    i ran aluminum pinion for speed runs less rotating weight
  13. #173
    Portugal
    293
    Yes with the neu motor just the size of the stock velenium.
    With no dremel work a 35t with 45 spur will work? or even a 36t pinion?
    i understand that for 37pinion it had to dremel a little... but i want to know the question up!
    thanks
  14. #174
    Feb 2013
    lancaster county,pa
    72
    Does the nue 1110 have the torque of a 4600kv castle. Trying to figure out what way to go.
    Sorry to hijack.
  15. #175
    so cal
    9,245
    The 35 should fit with no mods
    I have not compared the two together but I know someone who went from the 5700 to the 1110 and didn't lose any speed but gained handling
  16. #176
    Portugal
    293
    Quote Originally Posted by jamlx1 View Post
    Sorry to hijack.
    if it's a neu motor, even smaller size it as real man's Torque do bend steel...
  17. #177
    so cal
    9,245
    Turns smooth now!
  18. #178
    so cal
    9,245
    This was my favorite hill climb before these air gunners did this!
  19. #179
    so cal
    9,245
    Another thrashing
  20. #180
    so cal
    9,245
    Bump for no responses
  21. #181
    Poconos
    303
    Sorry to see them cut up your climb/jumps. Guess you will have to make some new ones!!!
  22. #182
    so cal
    9,245
    The hill climb was pretty hard to climb it with my merv (erbe no problem)so if I can rework it I will
    Don't want to make it too easy. You have about ten feet of flat on top then some thick brush. Once in a while you hit it right and land 15ft down the other side
