Page 3 of 5 FirstFirst 12345 LastLast
Results 81 to 120 of 182
  1. #81
    so cal
    9,244
    Just checked it out. There is a lip on the bracket under the motor and it is very snug. Motor isn't going to budge
  2. #82
    532
    Does the shock mount need to be grinder to fit the Neu motors?
  3. #83
    so cal
    9,244
    Not the 1110 only the 1112 its longer
  4. #84
    Aug 2012
    Toronto
    414
    Looking forward on your results when you get ur lil gizmo in
    I think the shock mount is fine if you don't mind having a bit of a rub
    It is metal to metal, so I guess even a cardboard in between will help with the vibrations til the next time you you do a gear change
  5. #85
    so cal
    9,244
    If I was to put anything in between I would have to do some more dremal work .it is that close!
    I ended up pulling it apart and doing more grinding . Now there is more clearance and I took a chunk of hard plastic and made a bump stop to fit snug. A drop of superglue then a dab of silicone to hold it in place. Much better now!
    Looks like the eagle tree elogger will be delivered this morning!
    Now if only the roads would dry up!
    Here it is! Looks like fun.
  6. #86
    so cal
    9,244
    Reb ilt the hr shocks with some green slime and put some Traxxas 7063t titanium nitride shafts 80wt oil summit springs up front and gpm gold.in the back
    put the gpm's on the other merv
  7. #87
    so cal
    9,244
    Tested out the eagle tree gps. With a single cheapy 25c 2200 2s ran 40mph at 25691 rpm pulled 538 watts and 53 amps
  8. #88
    Rotterdam, Netherlands
    7,313
    Lol. I see one more datalogging addict
    Good to see you got it working.
  9. #89
    so cal
    9,244
    Looks like it will be fun!
    Had a little setting up to do. Going to try to do a few runs tomorrow
    Now I wish I didn't shorten all the wires so much!
  10. #90
    so cal
    9,244
    Just weighed my car with the 1112 and eagle tree installed 3.04 lbs. Felt like 5 lbs compared to my other merv at 2.46 lbs
  11. #91
    Jun 2004
    1,894
    With batteries and body?
    ***You Build It ...I'll Jump It!!!*** OS .18 TZ; Trinity Pipe; HCR Titanium Skid Plates & Bumpers; Futaba S9450 Throttle Servo; Airtronics 94358Z Steering Servo; RPM A-arms & Knuckles; FOC; Lunsford Titanium Hinge Pins,Turnbuckles, Push Rods & Rocker Posts; New Era Roll Bar & Engine Mount; Proline Mashers on Velocity Rims.
  12. #92
    so cal
    9,244
    no without always thought it was heavier though
  13. #93
    so cal
    9,244
    3.5 with body, two batteries, aluminum bulkheads, trans,rockers,pushrods and toe links and eagle tree with gps and rpm sensor
  14. #94
    so cal
    9,244
    I ordered some taller 3.87" foam tires.
    Now I can keep 33/45 to bash off road and on 2s run 40+ with dirt hawgs and with the taller foams with the same gearing on 3s run over 60 and can't wait to find out how fast running 4 cell!
  15. #95
    Australia
    384
    Wow, that's just insane! All you need now are wings, and it'll fly.
    "With Great Speed Comes Great Repair Bills!"
  16. #96
    so cal
    9,244
    Just came back from a 2 cell speed run. I was expecting around a 40mph run with the gearing and low kv motor.
    ran a 48mph guess the old dirt hawgs need a new tape job!
    32663 rpm 51.81 amps and 391 watts
    Who needs 4 cell!
  17. #97
    Australia
    384
    How fast are you hoping this to go at the end of this.
  18. #98
    Jun 2004
    1,894
    When are you going to try some 4s speed runs, I thought you would have done some by now.
  19. #99
    so cal
    9,244
    my back/neck has been worse than ever and now waiting on the taller foams. problem with a 70+ mph run is you need a nice long road and at least two people in case you crash .it would take forever to get to it .where i run them is good for 65 max with a dip at the end and a bend in the road where cars could come with no notice! i am searching for a better road but don't want to travel and hour to get there
  20. #100
    so cal
    9,244
    While accelerating drew 54.77 amps and 511 watts battery voltage dropped to 7.4 v
  21. #101
    so cal
    9,244
    Less friction and drag on the way.ordered the yellow seal ceramics and those taller 3.87" foams should be in anytime now. Anyone want an update on performance?
  22. #102
    Oct 2012
    9
    Absolutely
  23. #103
    Vic. Australia
    163
    Max Speed??
    1/16 EREVO, 1/10 SUMMIT
  24. #104
    Australia
    384
    Quote Originally Posted by Beaz View Post
    Max Speed??
    It says so a bit further up.
  25. #105
    so cal
    9,244
    the taller foam i ordered aren't here yet. that's what you get for trying to get the cheapest price.the company is only an hour away but i ordered them five days ago and says still awaiting shipment
  26. #106
    Aug 2012
    Toronto
    414
    Those yellow seal ceramics, are they going on the motor or somewhere else?
  27. #107
    so cal
    9,244
    full set for the car .
    i have read that steve neu doesn't recommend ceramic bearings in the motor because when a ceramic bearing goes bad there is no warning and can damage a motor in seconds. others have ran them i have them in my 1110 .
    i emailed castle but they haven't returned my email
  28. #108
    so cal
    9,244
    Might pu some Boca ceramics for the moto had Goodnight.last tims
  29. #109
    so cal
    9,244
    Crazy spell check!
    that was
    Might pu some Boca ceramics for the motor ran good last time
  30. #110
    Aug 2012
    Toronto
    414
    You'll have to edit the title to add the 9000kv to the ultimate test.
    Looking forward to the results on the 4s run
  31. #111
    so cal
    9,244
    Ha. Yep! I have been waiting on my new foams so I wouldn't have to change gearing to 37/45 but looks like the company stiffed me. So now waiting for a refund!
  32. #112
    Jun 2003
    Estes Park, CO
    921
    4s with a 9000kv, 133k rpm @ 14.8v. I see possible motor carnage in your future. Sucks that your foamies didnt get done, im thinking bout getting a set done. You planning on doing a chart of some sorts with these motors and your eagletree? I think it's bee cool seeing actual numbers, then again I love geeking out on data.
    Dye-no-mite Pow-er Go Fast, Wirrrrr Screeeech BOOM
  33. #113
    so cal
    9,244
    actual under load kv will be much lower than 9000kv and so will the voltage with our small batteries .even with small 3.3" tires and conservative gearing it won't need half that rpm
  34. #114
    so cal
    9,244
    I have full recordings of the runs but to post them I don't know. Record it on my phone then send it to photobucket
    Without the taller foams I will have to gear up which I was trying to avoid. Its a pain removing the rear shocks and brackets for a few speed runs!
  35. #115
    Oct 2012
    9
    50, those shoes in #1 look sic, do they fit using same hex etc without any mods? linky maybe...
  36. #116
    so cal
    9,244
    I ordered an erbe today to go with my 2 mervs. A brand new Kawasaki edition!
  37. #117
    so cal
    9,244
    Bad news and good news.
    My foams I ordered won't be coming. Good news I did a dispute with PayPal and got my money back already!
  38. #118
    Aug 2012
    Toronto
    414
    Congrats on the Kawasaki!
    At least you got ur money back
    Interested to see what you'll get the erevo to push, ?mph...
  39. #119
    so cal
    9,244
    thanks it will be nice!
    with the smaller foams i will just have to gear higher . now just waiting for the boca yellow seal bearings to come in on the 7th and find a nice long smooth road!
  40. #120
    so cal
    9,244
    More parts today!
    Now just waiting on the futaba!
