Thread: Brass tubing
    Montreal, Canada
    537
    Brass tubing
    I receive my 9/32 brass tube with Teflon liner, I see that the stock were bend, do I have to do this also on the new one?
    Sharing is the best thing to do on EARTH legally.
    Delaware
    1,178
    You should. I bent mine straight, then put a gradual curve in the whole thing. It came with a fairly tight bend about a third of the way towards the rear. The bend keeps the shaft from having to make an abrupt turn before exiting the hull and entering the strut.
    To the men and women of the US military, thank you
    Nov 2011
    Pa
    571
    Yes. The stock tube is bent for a reason. Match the stock tube and you should have no issues
    Beatings will continue until compliance is gained
    uh oh.... that didn't sound good
    Jun 2011
    369
    I ran one boat all summer with the stock bend and the other boat with a straight tube. I have several hundred runs between both boats. No difference. As long as the strut is in proper alignment with the brass tube coming out everthing runs great. I grease every two runs and both cables are always clean and in good shape.
