Page 2 of 2 FirstFirst 1 2
Results 41 to 43 of 43
  1. #41
    94
    just came in from trying to run it. Got through 3/4 tank before it stalled after having a hard time starting it. I richened the HSN 1/4 turn per break-in instructions and tried to get through the last 1/4 tank with no luck. I will try to do the second tank tomorrow. The temps stayed good. i checked the flywheel compression and it seems to be less than before. Any help?
  2. #42
    94
    just tried to do another tank. After about a minute the engine went crazy and made a high screaming noise, as if it were goin g full speed even though throttle was all the way down. I brought it in to check temps and they were at 273 degrees.
  3. #43
    Marshal Nitronaught's Avatar
    Oct 2005
    18,032
    Quote Originally Posted by Icero1 View Post
    Check your spur that the slipper isn't too loose, but it sounds like the clutch spring may have let go. OR did the the flywheel come loose easy to tell that one..
    Founder of H.U.A.
    Hop Ups Anonymous
